Message 1 of 35
Flashing Purple Lights on the Hub
I was supposed to have my broadband activated yesterday. I did not get any message that it was done (like I was told I would), but the next day I could the see pending order had disappeared and MyBT was showing that I have a broadband connection, and when I called up I was told that my broadband should be working now
But when I connect the hub to the socket via the cable and filter all I get is a flashing purple light (after a period of steady green).
I'm really regretting trying to switch to BT, given the progress so far, but does anyone know what this means and what I can try to fix it? They are saying that my broadband is working now and I am now bound by a years contract 😞
I have seen a couple of people reporting this issue but no resolution, Does this ever get sorted or should I bite the bullet and pay myself out of this?
34 REPLIES 34
Message 2 of 35
Re: Flashing Purple Lights on the Hub
Welcome to this customer to customer forum.
Which one of these matches your master phone socket?
Message 3 of 35
Hi Keith
Thank you for replying.
I believe the second one is the closest. It has only one socket ( to be honest I am not in the property at the moment, but I will have almost no internet access when I am actually in it of course, unless I can read this site on my mobile)
Message 4 of 35
Is your phone line working at the output of the microfilter?
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Do you have any phone extensions connected, as they can stop broadband from working?
Message 5 of 35
hi Keith I believe the phone line to be working. (It was only activated yesterday as part of a home move). I was getting a dialtone after connecting the filter as well, though I haven't tried calling anyone, I did not notice any noise.
Message 6 of 35
Which BT home hub are you using?
Message 7 of 35
Only purple on HH6 Smiley Wink
Message 8 of 35
I don't know at the moment. But it should be new, I was sent the equipment on the 7th Dec(as I was newly trying to sign up to BT) for an activation date of the 8th which was missed.
Message 9 of 35
If you have dial tone (and checking with 17070 it is the right number), the problem is either the hub is faulty or your service hasn't been correctly activated.
Message 10 of 35
Hi Keith the line is fine and the 17070 test is fine. What would you advise I do next?
