loader85
Message 1 of 3
Flashing green light on router all day yesterday and today it's fine
I rang in an issue yesterday as my router was flashing green all day, it's happened twice before and I couldn't access to via wifi or lan. They arranged an engineer but today the router is fine again, I recontacted support as to not waste an engineer and suggested it was a hub fault?
Theuy said there is a fault at the cabinet, which may be true, but why was I not able to get any wifi connectivity from my router? I can if the phone line isn't plugged so it surely can't be the fact that no signal is being received.
I basically don't want this to happen again and for an engineer to come and tell me that I need a new hub amd.then have to wait even longer if my service cuts out again.
Thanks guys
2 REPLIES 2
loader85
Message 2 of 3
Re: Flashing green light on router all day yesterday and today it's fine
Just want to reference a post I found https://community.bt.com/t5/BT-Infinity-Speed-Connection/Home-Hub-5-flash-green-light/m-p/1437404/hi... , I've also seen that I may be charged for the engineers visit.is this true? I tried to provide enough informatio.
imjolly
Message 3 of 3
You may be charged if the problem is due to your setup or if your internal wiring are causing the fault otherwise there is no charge
