Message 11 of 16
Re: Fon and openzone on same hub
Yes, but you might find that your hub will be updated overnight by Bt until the update has been processed, and you are opted in, not on the Fon website, but on your hub. Just check tmrw with your phone, or your PC if its wireless as well.
We'll all be cybermen in the morning (second time I've said that on the forum).
AQ.
"Welcome to Royston Vasey - You'll never leave."
Stormbringer
Message 12 of 16
yep i realise they will update the hub overnight or at some time in next 48 hours anyway thx again 🙂 hey could be worse we could wake up as daleks
Stormbringer
Message 13 of 16
ok hub is reset and both oz/fon are gone , opted back into fon and awaiting it to appear on hub , i do have an option on the hub to activate fon , but im guessing i should wait till its done remotely
StevenLangdale
Message 14 of 16
Hello
I'm pretty sure seeing BTFON & BTOpenzone is normal.  Mine has always shown the pair of them & my own SSID.  Both on my old 1.5 hub and my newer 2.0 one.
Steven
Stormbringer
Message 15 of 16
ok did the reset etc and reregistered for fon and both oz/fon appeared on hub lol , guess i will just have to live with it
thx for everyones help tho 🙂
SidCup
Member
Message 16 of 16
Hi, i have this issue too so thanks for advice.  Although there is an option to opt out of FON I won't do so as I have found it really useful to log in on my travels.
