Guru
Message 41 of 75
Re: For mod's to check ( speedtester)
No problems here, worked fine for me at 8:10am
Distinguished Guru
Message 42 of 75
Re: BT Speedtester - 'Number of Threads are 4' Error
Hi whoosh
What type of hume hub do you have? V1,V1.5,V2 (type a or b)?
-+-No longer a forum member-+-
whoosh
Message 43 of 75
home hub is type B
to re-iterate
same result with FireFox or IE8
works fine on BT Business BB line with netgear - no BT vision
fails on Home BT line home hub 2 with BT Vision - box connected
fails on 2nd Home BT line home hub 2 with BT Vision - but no Visionbox connected
worked fine on both lines up until about a week ago
Tags (2)
whoosh
Message 44 of 75
Roger
what version Home Hub have you 1, 1.5 or 2 and if it's 2 is it an A or a B, do you have BT Vision?
Distinguished Guru
Message 45 of 75
Thanks Whoosh. It'll give BT a better pictureSmiley Happy
Guru
Message 46 of 75
I'm using my netgear router atm, no bt vision.
whoosh
Message 47 of 75
so it appears to be BT Vision enabled lines with a BT hub that is the problem....
Come on BT get it fixed please......
whoosh
Message 48 of 75
MODS
can we have these threads combined please- same issue
speedtester is failing on lines with BT Vision - and has been for over a week
http://community.bt.com/t5/Broadband-in-the-home/For-mod-s-to-check-speedtester/m-p/1042/highlight/f...
Guru
Message 49 of 75
I think you'd need more "evidence" than that...I wondered whether it was something as simple as cookie clearing?...eg, as FF shuts down, cookies cleared?....dunno, a mystery so far.
Have you tried updating your java version?...is it enabled ok?...a few things maybe to look at.
Dorset_Vinney
Message 50 of 75
When a zero cookie IE8 browser and a well customised Firefox 3.6 give the same result at all times of day, for numerous customer, then I'm inclined to look at the BT end of things rather than my own.
Dorset Vinney - I speak up when I'm worried
