Distinguished Guru
Message 11 of 75
Re: BT Speedtester - 'Number of Threads are 4' Error
If you're using Firefox that's the reason.
I've had it confirmed bt BT that speedtester is only configured to run on IE.
Having said that it used to work for me using FF.
Some forum members can still use it.
If you're using IE I'm not sure.
-+-No longer a forum member-+-
GeneralDisquiet
Message 12 of 75
DS - Speedtester is still working fine for me on FF3.6 - so I think you were being told porky pies (again)!
"To forbid us anything is to make us have a mind for it."
-- Michel de Montaigne, Essays, 1559
Distinguished Guru
Message 13 of 75
GD. I think we had our first cross post!
Just tried using 3.6 and got
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, [no address given] and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Apache/1.3.27 Server at speedtester1. speedtester . bt . com Port 80
I'll give IE a dusting down later and give that a go.
Distinguished Guru
Message 14 of 75
@ iainkirk. Your message is exactly the same as what I used to get on FF.
I was expecting to see it again but got the above.
Distinguished Guru
Message 15 of 75
Re: For mod's to check ( speedtester)
@ usernoname. Just tried using Firefox 3.6 and got the exact message as you.
There's definatley gremlins in the system.
I used to get to 96% complete and thats where it would stay.
a_rad
Message 16 of 75
I generally use - http://217.32.105.42:50301/ , doesn't work otherwise. Fails at 96% using FF 3.6 on linux if I don't use that url.
Half Man Half Biscuit - Joy Division Oven Gloves - Save 6
GeneralDisquiet
Message 17 of 75
I'm not sure what the problem is, but I am fairly sure its not FF3.6
I've just run it again to prove the point!
GeneralDisquiet
Message 18 of 75
"Number of Threads are 4" flashes up for an instant before the speed test completes - when it runs properly.  Not sure that helps much.
Incidentally, I just ran Speedtester again for your benefit - see here
Distinguished Guru
Message 19 of 75
I beginning to think this might be linked to Vision as you don't get the QoS green bar.
I 'normally' get two results on the page not one.
Anyone else having problems got a BT Vision box?
GeneralDisquiet
Message 20 of 75
Good thinking DS - not having a BTV box cos my line is way too slow (Sob! - that's twice you've reduced me to tears tonight!) I'd not thought of that possibility.
Couldn't you unplug the box and try without it - or would that mess up too many other things to be worth it?
