Christine
Message 51 of 75
Re: For mod's to check ( speedtester)
Latest java installed...cache cleared...cookies deleted....still hangs for me!!
whoosh
Message 52 of 75
Smiley Happy
The last time it worked was 26th Jan
Why should cookies have anything to do with it - as it works fine in IE8 and FF on a BT Business Broadband Line with a Netgear router with no BT Vision -
It fails in IE8 and Firefox - on the BT Broadband lines with BT Vision enabled and has done so every day since
java is up to date, all patches applied to FF and IE and I regularly clear out temp internet files (infact FF clears all brwosing data/info/temp files/cookies when i close it)
If you look at the "other" thread you will see similar reports
Distinguished Guru
Message 53 of 75
Re: BT Speedtester - 'Number of Threads are 4' Error
And the BT Forum Moderation response is.................................................................wait for it..............is.......
-+-No longer a forum member-+-
Guru
Message 54 of 75
I dunno then folks, I dont have the problem, and have not had to investigate it from my end.....
merely trying to suggest things to look at....I'll keep me gob shut!!   Smiley Indifferent
Distinguished Guru
Message 55 of 75
Slightly off topic here but BT servers are NOT well.
Just tried comparing BB packages and got this
Server Error
This server has encountered an internal error which prevents it from fulfilling your request. The most likely cause is a misconfiguration. Please ask the administrator to look for messages in the server's error log.
using this link http://www.productsandservices.bt.com/consumerProducts/displayCategory.do?categoryId=CON-TOTAL-BB-R1...
Anyone else seeing this?
whoosh
Message 56 of 75
mailed them
Moderator-Retired
Message 57 of 75
Hi Guys,
Ok threads merged!
ta
Craig
BTCare Community Mod
If we have asked you to email us with your details, please make sure you are logged in to the forum, otherwise you will not be able to see our ‘Contact Us’ link within our profiles.
We are sorry but we are unable to deal with service/account queries via the private message(PM) function so please don't PM your account info, we need to deal with this via our email account :-)”
td-p/30">Ratings star on the left-hand side of the post.
whoosh
Message 58 of 75
Well done Craig - not only did you merge the thread but......
From not workin @ 8 am today
to
I have just checked it now and it's working on both of my BT Vision enabled lines
 Smiley Very Happy
Distinguished Guru
Message 59 of 75
Hooray its only gone and bloomin' worked!Smiley Happy
Booo STILL got the QoS issueSmiley Sad
Results Image  not loaded
<script type="text/javascript">// // <![CDATA[ paintProgressAndMessageOnBar(-1 ,"One Last Test Required" ); // </script> This Test comprises of two tests
1. Best Effort Test: -provides background information.
Download  Speed
6565 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 6565 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 7150 Kbps
2. Assured Rate Test: -provides background information.
Download Speed
551 Kbps
0 Kbps600 Kbps
 Download speedachieved during the test was - 551 Kbps
 For your connection, the acceptable range of speeds is 576-600 Kbps.
 Assured Rate IP profile on your line is - 600 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit FAQ section if you are unable To understand the test results.
NOTE TO MOD DEALING WITH THIS ON THE OLD FORUM. IF I CLICK CONTINUE I HAVE TO CHANGE BB USERNAME TO SPEEDTEST@SPEEDTEST_DOMAIN
Christine
Message 60 of 75
Test now working for me too.....Smiley Happy
