I have brought a Foscam Wireless Cam and it is working fine wirelessly over the BT HH3 home network.
However, the device is not shown in hub manager in 'home network'. I am trying to Port Forward so I can access it when out and about. I have allocated it to port 8091 but I cannot see the device in 'home network' to click on it and ad port forwarding.
Please help before I throw it out of the window
You need to assign it a static IP address using the camera interface, then port forward to that static IP address. You need to assign an IP address outside of the DHCP range of the home hub.
There is a worked example on the bottom of this page Port forwarding problems
This forum search will also help http://community.bt.com/t5/forums/searchpage/tab/message?filter=labels%2Clocation&location=forum-boa...
If you need more help, then please post on this thread. Thanks.
working at last !!! thank you.
Excellent
