Rabby
Message 1 of 5
Freeview HD
New to the forum but not sure this is the right place for this query.  Moved back to BT today and now have my You View box set up and running.   The problem I have is that it has not downloaded any of the HD channels.  I know we can get them because the tv in the other room has them.  Any suggestions?
Thanks.
4 REPLIES 4
Keith_Beddoe
Message 2 of 5
Re: Freeview HD
It does not "download" them, they come in via the TV aerial connection.
I am sure one of the YouView experts on this board will be able to help.
drhowells
Recognised Expert
Message 3 of 5
Re: Freeview HD
Not an expert, but I will see if I can help 🙂
First thing to check is what happens if you go to channel 101 in the Guide? This should be BBC 1 HD. There is also 102, 103 and 104 for the other HD channels.
ab79
Message 4 of 5
Re: Freeview HD
I would second checking these channels. It changed from 50 - 54 a few weeks and it took me an age after rescanning , checking connections etc before accidently discovering they had moved!
Rabby
Message 5 of 5
Re: Freeview HD
Thanks - rescanned and they appeared in the location advised.
