gstevens83
Message 1 of 34
Frequent Broadband Disconnections / Slow Speeds
I transferred from Sky Fibre to BT Infinity 1 at the start of October and for around the first week everything was good. Since then speeds have reduced from around 40Mbps to 10-20Mbps and I have constant disconnections.
First phone call to customer service and they claimed it was my router and provided me with a replacement (Smart Hub for another Smart Hub).
No change in service so i made my second phone call to customer service and carried out a speedtest via the BTWholesale site. I received download speeds of around 14Mbps which the operator claimed was too slow for my line but said leave it a week and if nothing improves then phone back. My line was fairly stable for a week but still slow so I'm assuming he must've been able to do something at his end to improve stability.
After a week stability greatly reduced therefore I made my third phone call in which the operator said my IP Profile was not correct and reset it. He said that I should wait 24-48 hrs and it will definitely be fixed. Not surprised to find that I still have disconnections (albeit not as bad. Yet) and my speed has not improved.
Could someone assist or provide some advice?
I've included the typically asked for information from my router
Product name:
BT Hub 6A
Serial number:
+084319+NQ63293865
Firmware version:
SG4B10002236
Firmware updated:
21-Oct-2016
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 0 Hours 29 Minutes 13 Seconds
Data rate:
800 bps / 18.00 kbps
Maximum data rate:
800 / 27809
Noise margin:
18.9 / 18
Line attenuation:
19.9
Signal attenuation:
33 REPLIES 33
john46
Message 2 of 34
Re: Frequent Broadband Disconnections / Slow Speeds
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
pippincp
Message 3 of 34
Try a quiet line test with a corded phone 17070 option 2.
Any noise report a line fault on 151
DavidM
Moderator
Moderator
Message 4 of 34
Hi @gstevens83 and welcome.
Your connection time is only 0 Days, 0 Hours 29 Minutes 13 Seconds. Have you been resetting the hub?
Cheers
David
gstevens83
Message 5 of 34
John,
As requested:
gstevens83
Message 6 of 34
No issues with quiet test,
gstevens83
Message 7 of 34
Hi,
The Hub went through one of its disconnection / troubleshooting / restarting cycles as it occasionally does.
Webby
Message 8 of 34
Are you connected to the master socket or an extension?
gstevens83
Message 9 of 34
Webby,
I am connected to the master socket, and more precisely to the test socket with microfilter for the last few days to see if that will improve things.
Webby
Message 10 of 34
You need an engineer visit.
