Message 1 of 9
Frequent Disconnect
I am getting frequent disconnects on my router. In the logs I have 46 of this type of entry over past 2 days alone.
Line 830: 11:47:13, 30 Jul. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
Line 915: 11:43:52, 30 Jul. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
Line 1016: 11:36:29, 30 Jul. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
Line 1068: 11:35:01, 30 Jul. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
Line 1164: 11:28:45, 30 Jul. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
Line 1231: 11:27:22, 30 Jul. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
Line 1304: 11:25:36, 30 Jul. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
The router goes through complete flashing orange back to blue every time.
Very little using link at the time. For most of the 29th July, there was no-one in the house at all, so no active use. I have 30+ entries when no-one at home. This is getting frustrating as it will sometime have multiple disconnects when using catch-up TV.
Complete log has been exported if required.
Firmware version: v0.27.06.04290-BT
Firmware updated:21-Jul-2021
No extensions cabling is in use.
System using Wi-Fi only Main PC is off line.
8 REPLIES 8
Message 2 of 9
Re: Frequent Disconnect
Check for noise on your line. 17070 option 2 best with corded phone.
Message 3 of 9
no corded phone available at the moment, but line sounds clear enough .
Spoken message is certainly clear enough.
Message 4 of 9
What does "clear enough" mean? It should be silent between announcements. You may get a dull hum with a cordless.
Message 5 of 9
there was some very low level noise and it was constant. Nothing that I would consider significant, I did have to listen hard to hear it.
Message 6 of 9
Using a cordless phone when doing quiet line test a dull hum is normal and anything else is a problem for broadband and needs to be reported to 151 as a line fault not broadband
Message 7 of 9
The disconnects are random and not in any pattern that I can see.
In the past 48 hrs, there have been 6 seperate disconnect events. Each event may consist of several retries before I get a stable connection.
It may be a couple of days between events or I may see several over a coulple of hours.
I used MyBT line test and used the 'not happy about results' and this has resulted in an engineer visit on Monday. No fault details were given.
I will get hime to do a quiet line test while he is here.
Message 8 of 9
rummaging through the logs and looking for how long this may have been happening. Sadly does not go as far back as I would like as I get a WAN Log limit reached.
As for noise, I see that the SNR Margins do have some variance.
Downstream runs from 1.8dB to 10.7dB, around 7dB seems to be and average, without extracting all the values and putting them into a spreadsheet it is impossible to be accurate.
Upstream covers 0dB to 6552dB, not sure I trust that value though.
Line 882: 11:45:59, 30 Jul. DSL Link Up: Down Rate=19999kbps, Up Rate=556kbps; SNR Margin Down=10.1dB, Up=0.0dB
Line 890: 11:45:12, 30 Jul. DSL Link Up: Down Rate=19999kbps, Up Rate=547kbps; SNR Margin Down=10.2dB, Up=6552.4dB
Tried the Quiet Line test when the link was down and it does not sound any different, but it could always be a spike I missed.
Message 9 of 9
Hopefully engineer visit on Monday will solve the problem
