Nannysoo
Message 1 of 13
Frequent Loss of Internet Connection
Please help!!! I keep losing connection to the internet--not just once in a while but it's now happening several times a week. I am fed up of going round in circles on the BT troubleshooting pages because I can't contact them for help until I can reconnect( I don't have an endless supply of laptops and tablets) and so then when they "run tests" everything appears normal.
I used to be with Sky---I had NO trouble at all with Sky! However I bought a Smart TV and needed a faster internet to be able to watch it---I chose BT Infinity---disaster!
I have an almost new Lenovo Touchscreen computer.
YES - I connect wirelessly
Router is 8 foot away from my computer in an upstairs room (exactly the same place the Sky router sat).
NO - we do not have lots of devices trying to connect at the same time
I would welcome ANY solutions please as I am wishing I had stayed with Sky and taken the Smart TV back to where I bought it!
Thank you in advance.
12 REPLIES 12
imjolly
Message 2 of 13
Re: Frequent Loss of Internet Connection
have you turned of smart setup
Turn Off smart setup
have you split the networks
Split the networks
you can try downloading inssider3 (istumbler if MAC) and then run it. This will show the broadcasting networks round about you and their channels including your own. If you then enter your router and change your wireless channel to a free or less congested channel.
inssider3.1.2.1
Have you changed the default wireless lease time in the hh5 from 1 day to 21 days?
Nannysoo
Message 3 of 13
Thank you for all that information Distinguished Sage
imjolly
Message 4 of 13
That's not oldSmiley Wink
that's why I posted links which explain how to check and make the changes
licquorice
Message 5 of 13
Sorry, but what has being 62 years old got to do with anything. I suspect most of the regular posters here are older than that, I certainly am. Its not at all technical, just follow the instructions in the links, quite straightforward.
Nannysoo
Message 6 of 13
But why have I got to do all that when i had no trouble at all with my Sky router and I had that a good few years?
imjolly
Message 7 of 13
The hh5 is a different router and is dul band network whereas your sky router may have been just a single band. Maybe you can get one of your grandchildren to make the changes for you
licquorice
Message 8 of 13
Sorry, but why ask for solutions if you don't intend to implement them.
Nannysoo
Message 9 of 13
Right, I've switched of the Smart thingy and split the network watsit so I'll see how it goes over the next few days before I try the other one.
It was so easy with Talk Talk and Sky because you could actually speak to a human and they would talk you through things as you did them
Nannysoo
Message 10 of 13
Why don't you be quiet if you can't be helpful?
