Monkey_Jabba
Message 1 of 8
Frequent and random ADSL line drop / resync with Homehub v2.0 Type "A"
I am getting frequent and random ADSL line drop / resync, the router stays up, just the ADSL goes down then back up. This has only started since I moved from a v1.5 to v2.0 hub. The External IP stays the same but of cause the Profile drops so does the speed as it won,t stay up for more than a day (Sometimes only hours).
I have tried  a quiet line test,   Dial 17070 option 2, no problems with this.
So it all seems to be down to the v2.0 Type “A” hub with firmware 8.1.H.J
ADSL line status
Connection information
Line state Connected
Connection time 0 days, 0:13:39
Downstream 8,128 Kbps
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.1
Latency type Interleaved
Noise margin (Down/Up) 5.6 dB / 19.0 dB
Line attenuation (Down/Up) 35.0 dB / 20.0 dB
Output power (Down/Up) 19.8 dBm / 12.1 dBm
Loss of Framing (Local) 0
Loss of Signal (Local) 3
Loss of Power (Local) 0
FEC Errors (Down/Up) 769 / 0
CRC Errors (Down/Up) 1 / 2147480000
HEC Errors (Down/Up) nil / 0
Error Seconds (Local) 17
Anybody got any thoughts, I see lots of people seem to have the same problems. I may just go back to the v1.5 hub and forget the “N” WiFi.
7 REPLIES 7
Monkey_Jabba
Message 2 of 8
Re: Frequent and random ADSL line drop / resync with Homehub v2.0 Type "A"
Well the ADSL has stayed up, but not sure about the FEC Errors they seem a little high:-
ADSL line status
Connection time 0 days, 19:06:06
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Noise margin (Down/Up) 6.4 dB / 19.0 dB
FEC Errors (Down/Up) 4157379 / 0
CRC Errors (Down/Up) 68 / 2147480000
Error Seconds (Local) 63
Can anybody from BT comment please.
Monkey_Jabba
Message 3 of 8
Ok, well its has continued to drop the ADSL line (Stayed up for almost 2 days!!!!) so its back to the v1.5 Hub
DSL Connection
Link Information
Uptime: 0 days, 2:24:16
Modulation: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,808
Data Transferred (Sent/Received) [MB/MB]: 9.23 / 219.09
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 19.5 / 37.0
SN Margin (Up/Down) [dB]: 20.0 / 6.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 0 / 0
FEC Errors (Up/Down): 0 / 27,494
CRC Errors (Up/Down): 0 / 7
HEC Errors (Up/Down): 0 / 5
Line Profile: Interleaved
Lets see if this can hold the ADSL line it always did, so its back to old faithful, this new Hub 2.0 Type "A" needs a better firmware, BT are you listening...Maybe when the next firmware comes out I may reconnect it but not until then......
Monkey_Jabba
Message 4 of 8
OK so I was wrong, the V1.5 lasted a day too before a reboot Smiley Mad Getting FEC, CRC errors etc....logging a fault with BT now.....
ADSL line status
Connection time 0 days, 4:09:12
Downstream 8,000 Kbps
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Noise margin (Down/Up) 5.8 dB / 19.0 dB
Output power (Down/Up) 19.8 dBm / 12.3 dBm
Loss of Framing (Local) 11
Loss of Signal (Local) 1
FEC Errors (Down/Up) 33824 / 0
CRC Errors (Down/Up) 8 / 2147480000
Error Seconds (Local) 8
Back on the V2.0 hub as the WiFi is better....
Monkey_Jabba
Message 5 of 8
My connection lasted 10 hours last night, then 5 hours today before it lost sync, and still no reply back from the BT helpdesk.....about this problem that I logged with them.
ADSL line status
Connection time 0 days, 0:00:59
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Noise margin (Down/Up) 5.4 dB / 19.0 dB
Loss of Framing (Local) 3
FEC Errors (Down/Up) 39 / 0
CRC Errors (Down/Up) 0 / 2147480000
Error Seconds (Local) 44
ADSL line status
Connection time 0 days, 1:26:48
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Noise margin (Down/Up) 5.7 dB / 19.0 dB
FEC Errors (Down/Up) 8779 / 0
CRC Errors (Down/Up) 7 / 2147480000
Error Seconds (Local) 50
Could it be the Noise Margin as it seems very low?
Monkey_Jabba
Message 6 of 8
So the story goes on, I have had 4 visits from BT engineers now, the last one has changed my cable from the Green road box to the exchange, I have replaced all the cables, ADSL filters, Router (another 2.0 Type "A") Hub phone etc.
But still it drops the ADSL line at 12pm ish every night????? The hub does not reset but it just does a resync, but the speed to the exchange is still low and so is the IP profile as it just wont keep the line up???
Not had the new hub long enough to see if it has random resets in the day....time will tell.
Just one point to note, the chap from the India help desk has been great and on the case all the time trying to help and book out the engineers.
Is this still a bug with the hub 2.0 type "A", does anybody else have the same troubles?
Monkey_Jabba
Message 7 of 8
Yesterday I get a call from BT saying they are going to reconfig the port at the exchange end (Remotly)....Well lets say Dropped connection 5 times already today, Speed and IP profile dropping to 3mb now.....gonna be on Dial-up speeds by next week.....
Come on BT give me some answers........And get my connection swaped out to a new card at the exchange.....
Monkey_Jabba
Message 8 of 8
OK so after weeks and weeks, it looks like it was the local exchange end with the fault.
The hub can now stay up for over a week etc no problems, I still get the odd few days when the ADSL drops 3 or 4 times a day, then its steady for ages, then goes funny etc.....
So it was not the HUB or the internal wiring in my house, it may have been the aluminium cable used by BT but that is now replaced with all copper to the exchange.
