Mjconnolly
Message 1 of 23
Frequent broadband disconnections
Hi everyone, hoping someone can give me some tips as to how to solve this. I have a Smart hub (6a) connected to an Openreach Mk4 socket. It has been very stable for months (since the new socket and hub were provided), but in the last couple of weeks it has been dropping out several times a day. I get the flashing orange ->orange ->blue light show and it reconnects. I reported a fault but all the people at the call centre want to know is how many wifi devices are connected. I have done a factory reset, several soft and hard restarts, none of them make the problem go away. The messages I can see in the event log always show this if I filter on PPP:
:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
Is this BT trying to do something to the router? Or could it be a router fault? Or do I need to lean on BT to get them to test the line properly (I've checked all over for damage to the cables in the house but can't see any).
22 REPLIES 22
pippincp
Sage
Message 2 of 23
Re: Frequent broadband disconnections
Remove the faceplate and connect directly to the test socket with a filter. Also try a quiet line test on 07171 option 2, any noise report a line fault don't mention broadband.
Mjconnolly
Message 3 of 23
I already tried the quiet line test and got no noise. Mind you my phones are rubbish so it's hard to know for sure... would the noise be obvious? I'll do the test socket thing later today.
Cheers
imjolly
Message 4 of 23
the noise should be obvious - crackle/hiss
Mjconnolly
Message 5 of 23
Hi, I think the quiet line test is fine. I only have cordless phones and there always seems to be a bit of a background hiss, but it does not get any worse during the test at least!
I've swapped to the test socket and the connection has been stable so far - probably too soon to tell if it's permanent. But my download speed is now only half what it should be (approx 40mb vs the usual 76mb). I'll try it again on the BT test with an ethernet connection when I get a chance.
Mjconnolly
Message 6 of 23
I ran the BT Wholesale test, and it reported that my IP profile was now 45.4Mbps... I've never known it be reduced before. How long does it take before that gets put back up to 80mbps again?
imjolly
Message 7 of 23
can you post the stats from your hub please - advanced settings/technical log
Mjconnolly
Message 8 of 23
Sure, here you are: (NB still connected to the test socket, should I put the faceplate back on yet?)
Product name:
BT Hub 6A
Serial number:
+084319+NQ64353844
Firmware version:
SG4B1000B316
Firmware updated:
29-Jul-2017
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
1 Days, 1 Hours 53 Minutes 2 Seconds
Data rate:
15.00 Mbps / 49.00 Mbps
Maximum data rate:
32541 / 93052
Noise margin:
16.5 dB / 17.8 dB
Line attenuation:
10.8 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
5237 MB Uploaded / 15418 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-XCS7
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-XCS7-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:4C:EF:35
Software variant:
Boot loader:
7.33.1
pippincp
Sage
Message 9 of 23
If your line is now stable in the test socket then leave it there for now. If it remains stable then DLM should relent and increase your speed again.
Personally if it's not causing problems I would leave as is until the line's recovered and speed has settled.
imjolly
Message 10 of 23
I would get a cheap corded phone and recheck the quite line test and if any line noise report a fault and get it fixed  until you can get a stable conenction your speed will not improve  if it has been dropping connection as often as you said and in addition you have been resetting then it could take a while for speed to recover
