Albie4464
Message 1 of 5
Frequent drop of DSL in Infinity
I,m becoming more and more frustrated with BT Infinity with very frequent loss of servive.
I have ahd Infinity for about a year and was very satisfied until recently when I could only have service for sometimes only a few miniutes. Then it returned for about five days with reduced speeds 27 down 4 up instead of35 down and 9 up. then that started dropping out too. I have raised the problem with BT who keep saying they cannot find a fault then all was well for 5 days until last Monday when drops started again. Infiity was aslf install, I do not have later Master sockets just two coming from a junction box in my property. Drops occur both with Ethernet and wireless connections. It may be significant that I live in a retirement flat within a complex. Recently our entry phonesand careline sytem have been renewed but a friend who lives in the same complex has not had any trouble but when she had hers installed it was done by BT with a new master socket c/w face plate and no need for filters. Occasionaly I have cracking on my phone line but a quiet test today proved OK.
My stats are here
1. Product name:BT Home Hub
2. Serial number:+068543+NQ41653016
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 01/07/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:07:42
6. Data rate:8491 / 40000
7. Maximum data rate:17481 / 82504
8. Noise margin:10.0 / 12.0
9. Line attenuation:13.4 / 13.4
10. Signal attenuation:13.3 / 13.4
11. Data sent/received:267.8 MB / 1.6 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-KWC7
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-KWC7
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:40:f2:01:14:88:ae
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
BT Home Hub 5 (Type A) | Software version 4.7.5.1.83.8.204.1.11 | Last updated 01/07/15
I have noted looking at the event logs that the following or something similar occurs frequently
10:26:56, 10 Jul. (512708.800000) PPPoE is down after 25 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
10:26:51, 10 Jul. (512703.670000) PPP LCP Send Termination Request [User request]
10:20:14, 10 Jul. (512307.390000) Admin login successful by 192.168.1.66 on HTTP
10:20:12, 10 Jul. (512304.500000) New GUI session from IP 192.168.1.66
10:03:59, 10 Jul. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.65]:50173-​>[17.172.232.80]:443 on ppp3)
10:03:59, 10 Jul. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.65]:50173-​>[17.172.232.80]:443 on ppp3)
10:03:58, 10 Jul. (511331.330000) Lease for IP 192.168.1.65 renewed by host Alberts-​iPad (MAC c8:b5:b7:08:74:a8). Lease duration: 1440 min
10:03:58, 10 Jul. (511331.330000) Device connected: Hostname: Alberts-​iPad IP: 192.168.1.65 MAC: c8:b5:b7:08:74:a8 Lease time: 1440 min. Link rate: 300.0 Mbps
10:03:58, 10 Jul. (511331.230000) Lease requested
Does anyone have any thoughts? Thank you
4 REPLIES 4
john46
Message 2 of 5
Re: Frequent drop of DSL in Infinity
you need to get that line noise fixed as that will cause disconnections
Albie4464
Message 3 of 5
Thank you for your reply. Are you referring to the occasional crackle or the noise margin shown in my stats, other posts suggest 6 is more normal but I don't know. Also is there any way to export the event log other than copy & Paste?
Albie
imjolly
Message 4 of 5
john46 comment was to get the line noise fixed when you us the phone
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone  if any noise then reposrt a phone fault to 151
in your case your noise margin above 6db is ok as you are on infinity 1 capped at 40mb whereas your line could go faster at infinity 2 max of 80mb
Albie4464
Message 5 of 5
Thank you. I have just repeated the quiet line test on a corded and Dect phone, there is intermittent slight noise on both. I have BT phoning me for updates on Monday, I will mention this.
Albie
