Message 1 of 2
Frequent drop outs on FTTP - LCP down
Hi all
I've been having issues with my FTTP (Fibre 500) for a few weeks now, and have had a case open since 21st August with BT / Openreach that still isn't resolved. Openreach have marked the fault as fixed a number of times, and haven't shown up for at least three appointments. I'm almost certain the issues lies between the property and the exchange so I don't think there's anything I can do but wait for Openreach, but I wondered if anyone else had had similar issues and managed to get a fix / what the cause was?
My speed slows down and then eventually stops completely. The ONT box will go from three green lights (power, PON and LAN) to flashing green PON to red LOS. Hub alternates between orange and purple. In the logs, there doesn't seem to be anything obvious happening before the disconnect:
07/09/2021 17:26:34 ARP [add] br0(wl0) 192.168.1.235 12:61:da:bd:a9:7a
07/09/2021 17:28:43 PPP: IPCP down
07/09/2021 17:28:43 PPP: LCP down
07/09/2021 17:28:44 PPP LCP Send Termination Request (Peer not responding)
07/09/2021 17:28:47 PPP LCP Send Termination Request (User request)
07/09/2021 17:28:50 PPP: Stopped PPP daemon(0,1,5)
07/09/2021 17:28:51 WAN Sensing Auto sensing Complete, interface selected
07/09/2021 17:28:51 PPP: Starting PPP daemon
07/09/2021 17:28:51 WAN Sensing Auto sensing Running
07/09/2021 17:28:51 WAN connection WAN1_INTERNET_ETH disconnected.[ERROR_NO_CARRIER]
07/09/2021 17:28:53 SIP WAN DOWN
07/09/2021 17:28:53 WAN Sensing Auto sensing Complete, interface selected
07/09/2021 17:28:53 WAN Sensing Auto sensing Running
07/09/2021 17:28:56 PPP: Sending PADI
...hundreds of PPP: Sending PADI messages later...
07/09/2021 19:23:40 PPP: Sending PADI
07/09/2021 19:23:40 PPP: Received PADS
07/09/2021 19:23:40 PPP: Sending PADR
07/09/2021 19:23:40 PPP: Received PADO
07/09/2021 19:23:41 PPP IPV6CP Receive Configuration ACK
07/09/2021 19:23:41 PPP IPCP Send Configuration ACK
07/09/2021 19:23:41 PPP IPCP Receive Configuration Request
07/09/2021 19:23:41 PPP IPV6CP Send Configuration ACK
07/09/2021 19:23:41 PPP IPV6CP Receive Configuration Request
07/09/2021 19:23:41 PPP IPV6CP Send Configuration Request
07/09/2021 19:23:41 PPP IPCP Send Configuration Request
07/09/2021 19:23:41 PPP: CHAP authentication succeeded
07/09/2021 19:23:41 PPP CHAP Receive success : authentication successful
07/09/2021 19:23:41 PPP CHAP Receive Challenge
07/09/2021 19:23:41 PPP: LCP up
07/09/2021 19:23:41 PPP LCP Receive Configuration ACK
07/09/2021 19:23:41 PPP LCP Send Configuration ACK
07/09/2021 19:23:41 PPP LCP Receive Configuration Request
07/09/2021 19:23:41 PPP LCP Send Configuration Request
07/09/2021 19:23:42 WAN DHCPv6 events: INIT
07/09/2021 19:23:43 WAN IPv6 Global unicast prefix / length: 2a00:23c7:ee0b:2e00::/56
07/09/2021 19:23:43 WAN IPv6 Global unicast address allocated: 2a00:23c7:ee0b:2e00::1/64
07/09/2021 19:23:43 WAN DHCPv6 events: BOUND
07/09/2021 19:23:44 PPP IPCP Send Configuration Request
07/09/2021 19:23:44 PPP IPCP Send Configuration ACK
07/09/2021 19:23:44 PPP IPCP Receive Configuration Request
07/09/2021 19:23:44 WAN Sensing Auto sensing Running
07/09/2021 19:23:47 PPP: IPCP up
07/09/2021 19:23:47 PPP IPCP Receive Configuration ACK
07/09/2021 19:23:47 PPP IPCP Send Configuration Request
07/09/2021 19:23:47 PPP IPCP Receive Configuration NAK
07/09/2021 19:23:47 PPP IPCP Send Configuration ACK
07/09/2021 19:23:47 PPP IPCP Receive Configuration Request
07/09/2021 19:23:48 WAN connection WAN1_INTERNET_ETH connected
There also doesn't seem to be a pattern to when it goes down, or how long it's down for, how long it's up for in between outages. It can be a few minutes to a couple of hours, slightly more often during the day than the night. Rebooting the hub, ONT, or both makes no difference.
21/08/2021 - 8 outages lasting 1:13:05
22/08/2021 - 8 outages lasting 2:00:27
23/08/2021 - 2 outages lasting 1:54:45
24/08/2021 - 7 outages lasting 5:47:36
25/08/2021 - 2 outages lasting 1:50:01
26/08/2021 - 2 outages lasting 1:42:12
27/08/2021 - 05/09/2021 - no outages
06/09/2021 - 12 outages lasting 5:03:37
07/09/2021 - 5 outages lasting 2:29:22
Tags (1)
1 REPLY 1
Message 2 of 2
Re: Frequent drop outs on FTTP - LCP down
Chances are that your particular ‘connection’ ( ONT, CSP, CBT port , Splitter leg ) has a high loss somewhere , and your ONT is effectively hanging into a sync by a thread, loses sync periodically (LOS) and comes back, and maintains sync for a while before failing again .
The issue could be where the Ezibend is plugged into the ONT ( needs a clean ) or a poor connection at the CBT ( maybe not fully tightened) or a dodgy splice at the splitter or CSP.
TBH you would think OR should send someone out to check the light ( power ) level at the ONT , and take it from there, anything dodgy from the splitter back towards the OLT is likely to be addressed pretty quickly as it would probably affect the entire PON and all users on it.
It’s also possible it’s the ONT itself.
