Bc1973
Message 1 of 2
From BT Vision to YouView
I'm told that my BT Vision contract has ended and that if I wanted to drop to a £4 per month tarrif (I was on £12.50 but used precius little of this) I can but it would mean signing up for a further year. Does this sound right?
Seperate to this I've been considering jumping to YouView as all I want from my TV service is the standard TV channels, the possibility of BBC HD, iPlayer & 4OD and I see BT will 'give' you a box if you sign up to the £4 tarrif.
Are there any extra costs involved with switching to YouView on BT? I'm told YouView can access LoveFilm, will it do this with BT or am I tied to their on demand film channel?
Tags (2)
1 REPLY 1
walkerx
Recognised Expert
Message 2 of 2
Re: From BT Vision to YouView
You pay for box and lovefilm not on it yet
