YetAnotherUser
Message 1 of 23
Frustrated with the engineers that keep reducing my broadband speed
I signed up for Infinity about 6 months ago. Performance on the first day was 38Mb/s
Then the engineers did some work in my street, and it dropped to below 8Mb/s
It took several weeks of negotation with BT customer services (I refused to pay until they fixed it) and the line was eventually restored to around 37Mb/s
Now the engineers have returned, done more work in my street, presumably to deliver recently advertised upgrades - but my downloads have dropped to 22Mb/s. So BT have taken away the bandwidth they were selling to me, and given it someone else?
I'm disgusted by the smoke & mirrors / give & take policies that BT has adopted. What are my options? Should I complain to the Ofcom, send BT a bill for the missing 16Mb/s, and cut the direct debit?
22 REPLIES 22
imjolly
Message 2 of 23
Re: Frustrated with the engineers that keep reducing my broadband speed
there is no roadworks required for the recently announced increases for infinity 1 - just software moving of capped speed from 40 to 55mb   nobody is stealing your bandwidth
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
 are you using master or test socket
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
YetAnotherUser
Message 3 of 23
There is only one observed pattern: When BT engineers visit the box in the street to do work, my broadband speed drops.
I'll try posting data but its logistically tricky because I don't use the expected hardware.
P.S. Just found this webpage doesn't work fully in the Windows 10 Edge browser. Cannot paste anything into the reply box.
umpire
Distinguished Guru
Message 4 of 23
"I know of the troubleshooting/helpdesk options and I verify my bandwidth using BT's wholesale speed check."
Could you post the info then? You know the results but the others on the forum aren't mind readers. 🙂
They might be able to offer advice if they can see the full picture.
umpire
Distinguished Guru
Message 5 of 23
Just text versions are fine if you are having problems with screenshots.
Haven't tried Edge with this forum myself. I believe Windows 10 does also have Internet Explorer pre-installed if you dig around?
YetAnotherUser
Message 6 of 23
Needed to switch browsers due to community.bt.com bug..
FTTC Range A (Clean) 49 35 9 6.3 -- Available
FTTC Range B (Impacted) 36.7 18 8.1 4.2 -- Available
WBC ADSL 2+ Up to 11 -- 6.5 to 15 Available
WBC ADSL 2+ Annex M Up to 11 Up to 1 6.5 to 15 Available
ADSL Max Up to 6 -- 5 to 8 Available
WBC Fixed Rate  2  -- -- Available
Other Offerings
FTTP on Demand 330 30 -- Available
Fibre Multicast -- -- -- Available
Copper Multicast -- -- -- Available
Speed Test Results
(samples observed today - values inconsistent)
Download: 22 - 34
Upload: 7 -  7.5
Ping: 21.3 - 22.5
IP Profile for your line is - 37.84 Mbps
Upstream Rate IP profile on your line is - 10 Mbps
Interesting: BT claims that 20Mb/s is within the acceptable range for BT Infinity, so I guess my only complaint can be that instead of making fanciful quotes, shouldn't BT be advertising "20Mb/s or better"?
Webby
Message 7 of 23
Are you testing with a wired or wireless connection?
Your IP profile indicates your connection speed is within the estimated range of speeds for your line.
imjolly
Message 8 of 23
you are on infinity 1 and from what you have posted have a 40/10mb connection  was btspeedtester done using a wired connection to do the test
YetAnotherUser
Message 9 of 23
My laptops don't have an RJ45 socket so these are wireless tests. It would take a while to find and dust off an older machine for more accurate tests - is that really worth doing?
imjolly
Message 10 of 23
BT will not help unless btspeedtester is done with wired connection due to possible interference using wireless
