Woody200575
Message 1 of 8
Fttp present but not able to order.
I am desperate for someone to help. I have now been promised three callbacks by BT and have not received any. Openreach shows fttp at my address, I have even had confirmation through e mail from openreach that it is here, but BT say it isn't. Nobody at BT seems to be interested in helping me at all. I get fobbed off constantly. I have complained and even this has been ignored, no acknowledgement at all. I rely on fibre to work and this is a nightmare. It has ruined my move to my new house and I'm at the end of my tether. I really think BT needs to look at how it treats customers.
7 REPLIES 7
pippincp
Sage
Message 2 of 8
Re: Fttp present but not able to order.
Enter your phone number HERE and post back the full result.
Remove your phone number before posting.
Woody200575
Message 3 of 8
BT BROADBAND AVAILABILITY CHECKER
Telephone Number on Exchange TAUNTON is served by Cabinet 98
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTP Availability Date
WBC FTTP Up to 330 Up to 30 -- Available -- -- -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 3 -- 1.5 to 5.5 Available -- -- -- --
WBC ADSL 2+ Annex M Up to 3 Up to 0.5 1.5 to 5.5 Available -- -- -- --
ADSL Max Up to 2 -- 1.5 to 4.5 Available -- -- -- --
WBC Fixed Rate 1 -- -- Available -- -- -- --
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- -- -- --
ADSL Multicast -- -- -- Available -- -- -- --
Our records show the following FTTP network service information for these premises:- Single Dwelling Unit Residential UG Feed with no anticipated issues.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
This line is on a Market B Exchange.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 31-Jan-2013; the Formal Retirement date for IPstream is from 30-Jun-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact the Broadband supplier they want to take service from to arrange for the service to be migrated.
Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check.
Note: If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service.
Thank you for your interest.
pippincp
Sage
Message 4 of 8
OK it says you can get it so ring this number 0800 587 4787 which is the fibre order team. They should get you sorted out.
Woody200575
Message 5 of 8
I have done this on multiple occasions and get told it isn't here. That's why I'm so frustrated.
Woody200575
Message 6 of 8
I have just gone on BT.com and checked the address using the phone number that shows up here and it is now saying fibre is available to order. Does that mean someone has finally updated the database?
Woody200575
Message 7 of 8
Cancel that. When trying to order it says infinity isn't available even though it says it is when it checks the Nunavut and address at the start.
pippincp
Sage
Message 8 of 8
The fibre order team use the same database I asked you to check. Now when you ring up they should see it as good to go.
Try tomorrow and if you have a problem don't pull your hair out just come back here.
