Message 1 of 6
Full Fibre 900 Speeds all over the Place .
Hi Guys,
Had Fibre 900 fer a few Months now but Finding it increasingly erratic ... Using Ookla  to Test & Fast.com
Each are all over the place
Test first time get 345Mbps.....
Test Second time 533Mbps..
Test a Third time 399Mbps...
Plus, using Ookla which Server do you Pick ??  the VERY nearest one to Me is 44 Miles away (TNP Ltd) or (Exascale Ltd)
Using "Fast"...Best I have EVER got out of "fast" is
440Mbps (Test One)
540Mbps (Test Two)
& can Someone tell me what the Figures are showing up in the Bottom Bar of the "Fast Test Screen"
"settings" is a "Given"  but what are the other Numbers ?? I have a Feeling they are what my Connection is "Capable of"  Correct ??????????????
 960MB 120MB
5 REPLIES 5
Message 2 of 6
Re: Full Fibre 900 Speeds all over the Place .
are you using Ethernet connection or wireless?
Message 3 of 6
Sorry I meant to put that. Ethernet Cat 7e cable direct to router
Message 4 of 6
@TheSeasider
I am on the same BT 900 / 110Mbps package as you (using my own Asus Router) and get these results which I'm sure isn't just correct.
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 5 of 6
Busterboy1
I can't get anywhere close to that even your latency is only 2 SECONDS!!!! Mines way off at 13 or 14 seconds. Its just crazy this 900 fibre. I'm too am using my own router (TP-Link Archer C7). On my old BT SH2 I was getting lower (a lot lower). than the C7. The speed just bounces all over & if you use Ookla you get so many different servers to try & EVERY SINGLE ONE comes back with a different speed.
My brain hurts just trying to think about it
Message 6 of 6
@TheSeasider
______________________________________________________________________________________________
Mine can vary depending on what server is chosen, I have had Latency as high as 16 - 18 before now.
I do find the Ookla varying speeds also and changing server does return different results.
Latency to London 200 miles away.
Higher Latency readings to other servers.
