Proz
Message 1 of 8
G.INP On Drops My Speed
I have an Asus AC68U modem which has the G.INP option to turn on/off.
If i have it off my max sync rate is 77 Mb/s
If i turn G.INP on my max rate drops to 59-65MB/s .... why would that be ?
I thought G.INP was meant to improve things .
I believe my cabinet is Huawei and my modem reprots the chipset is Broadcom.
Should i just leave G.INP off ???
7 REPLIES 7
Webby
Message 2 of 8
Re: G.INP On Drops My Speed
I think you've answered your own question
Proz
Message 3 of 8
If G.INP is meant to be so good then why does it slow my speed so much ?
Webby
Message 4 of 8
It's not always active even if a cabinet is enabled. So by simply selecting it on yor router, could be confusing DLM as it may not think G.INP is needed on your line at the moment.
G.INP is just a tool DLM has, it's not something that's always on.
TimCurtis
Recognised Expert
Message 5 of 8
In your DSL log does it show that G.INP is on & is it on for both downstream & upstream?
This is what my DSL Modulation shows in the log - "ITU G.993.2(VDSL2), G.998.4(G.INP, Downstream only)"
If it's not on but you've selected the option then just leave it & let DLM does it job.
Proz
Message 6 of 8
My Asus DSL-AC68U says the same as above. Downstream only. But when I turn it off I gain around 10MB/s sync .
TimCurtis
Recognised Expert
Message 7 of 8
Interesting
I just turned mine off & lost 3meg & destroyed my ping times.
Webby
Message 8 of 8
Moral of the story, don't try and fix something which isn't broken 😉
