imjolly
Message 501 of 535
Re: G.INP affecting certain eci modems,resulting in a drop in sync rate and other issues
The archer will need the openreach modem as it will not stand on its own as it is only adsl2 modem so can only use as router
licquorice
Message 502 of 535
If you want standalone you need the TD-W9980 which has a VDSL2 modem.
ewanb75
Message 503 of 535
I woundnt need anything if something hadnt upset my perfect line with the hub 4 and openreach 4 month ago...............
Barry57
Expert
Message 504 of 535
"THIS WAS 2 MONTHS AGO!!! and im still not updated!"
Looks more and more like were in a holding pattern till at least September.
The new superduper  football streaming  is fast approaching, so unless this "patch" fix starts to affect that,   why would bt risk breaking it even more  😄
john46
Message 505 of 535
G.INP is being rolled out by Openreach and affects all ISP.s not just BT
imjolly
Message 506 of 535
my HH5a was updated 4 days ago to ..204.1.11 so rollout of openreach fix is ongoing
McGrath1982
Expert
Message 507 of 535
So after all the problems with this G.INP since getting a HH5 type B it's not dropped out once can't say I've ever had up time of 36 days plus before.
1. Product Name: HomeHub5
2. Serial number: +076284+1445006482
3. Firmware version: v0.07.03.0814-BT (Type B) Last updated [Unknown]
4. Board version: 01
5. VDSL uptime: 36 days, 12:21:45
6. Data Rate: 19999 / 79999
7. Maximum Data Rate: 27965 / 91450
8. Noise Margin: 14.5 / 8.4
9. Line Attenuation: 0.0 / 15.2
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 32.2 GB / 382.8 GB
12. Broadband username: bthomehub@btbroadband.com
john46
Message 508 of 535
like wise i have a HH5b with over 100 days stable connection
RayW1
Message 509 of 535
FWIW, just received the update  to my HH5A at 09:28 this morning ...
Barry57
Expert
Message 510 of 535
 "my HH5a was updated 4 days ago to ..204.1.11 so rollout of openreach fix is ongoing"
Is that a new 3rd fix or is btretail just rolling out an update to make the hh5a work with ducktape/chewing gum patch*. ?
The eci/r modem users are still being left out then 😞
*(Ducktape /chewing gum patch seems to be called Mk2 according to the plusnet forum)
