So BT will of known simce the testing that their ECI & HH5vA Devices wouldn't work with G.inp then,? but they did nothing about that,
They just continued to supply their End users with devices they knew would not work satisfactorily once they have rolled out G.inp ?
either that or the testing they did if any wasn't done properly so didn't show the same failings or the results did show what customers have reported but they decided to keep schtum about it, hoping that the end user wouldn't notice ,lol either way it isn't very good for the EU is it?
They must of had an idea becasue they there telling openreach engineers back in January the eci would not even work on some lines.
From Kitz's site: {I'd post a link but it always gets reomoved}
"If the replacement modem is ECI (indicated on the box or base of the modem) it’s likely the firmware is incompatible with ReTX and a workaround needs to be applied. If you complete a DLM reset it will remove the ReTX profile and allow the modem to sync up ....."
The good people over at Kitz's and the guru's on here were warning people about the eci/r which I didn't really grasp at the time. I Remember Ray_Dorst being quite vocial on using a hg612 3b instead of the eci / hh5a....{Shame Ray's not around as much as I basically just repeat his advice} 😄
Still think that November court case BT lost ( on the dlm) had a big impact which was more that first thought.
I take it those of us using a third party router+modem like the ZyXEL SBG3300 shouldn't
suffer from any of these issue once G.inp has been enabled for our cabinet?
I'm not sure 100%
Imagine so if there been some updates ? The Zyxel's vmg seem to very popular over on kitz & pn.
Its such a big can of worms at the moment on what 100% works, what doesn't & what needs an upgrade. 😞
Hence I just stick with recommending the hg612 3b (or the hh5b* if the port issue is fixed?) as we all know by they just work.....
It's not a can of worms at all, either the device supports G.Inp or it doesn't. Currently, I believe all the popular third party devices support G.Inp
Might be simple to the gurus.. I thinking its a can of worms
Take your device , the tplink only works through the good will of tplink support.
"supports G.Inp or it doesn't"
Wont that just apply to broadcom as I believe g.inp is proprietary to broadcom?
Its not just if retransmisson works or doesn't, its the tv muilt cast stuff as well.
I was looking at the fitzbox for example, which supports downstream retransmission but not the mulit cast stuff when I emailed avm to ask.
Then there is this new 4k streaming which could mess things up again.
If bt mess things up (odds on as it bt) again you may be back to square one, emailing tplink hoping for fix 😉
Forget the multicast stuff that is a totally different thing. G.Inp (G998.4) IS NOT PROPRIETARY it is an ITU standard. Broadcomm implemented their own version early on. Hence a device either supports it or it doesn't. Nothing to do with good will, its commercial sense to implement standards where possible.
We just agree to deffer :
As I'm coming from a slighty different angle and viewing the 3rd party products in totality with bt product offerings.
May or may not work with retransmission - May or may not work with mulit cast tv. There is a lot of combinations and easy to get wrong.
Your tpink device worked with Mulitcast but not Retransmisson.
Easy mistake to make when there are so many pitfalls when viewed in totality. Fingers crossed tplink offer the same next time bt mess up.
With the hg612 3b or hh5b both work with retransmisson & both work with with mulit cast tv.
Also both being bt based you will receive serviced based updates / upgrades {even if there not always welcome}. Not "good will" or "commerical sence" updates, which could change at the drop of a hat if a newer verison more singing and dancing model is realised.
Of course none of this would matter is bt could get things right in the first place!
All of the above is in good jest & where Ray when you need him 😄
are you not on an ECI cab and G.INP is not affecting you at present you changed because your conenction was dropping with the hh5a and adding the modem has helped with your disconnection problem at present who knows what is happening with ECI cabs
