McGrath1982
Expert
Message 81 of 535
Re: G.INP affecting certain eci modems,resulting in a drop in sync rate and other issues
Same here contracts up in May so looking at other ISP at the moment tbh...
ray_dorset
Distinguished Guru
Message 82 of 535
@McGrath1982 you could try a long factory-reset on your HG612 which will lock the modem but should allow BTAgent to automatically upgrade the firmware if you can't do the firmware upgrade yourself.
If not, I'll try again 🙂
McGrath1982
Expert
Message 83 of 535
I'm gonna leave for a couple of days as I tried 3/4 times last night but couldn't get back into the HG612 and don't won't to make things worse with the line I will have a go at a factory reset @ray_dorset
-AndyH-
Expert
Message 84 of 535
@Locky wrote:
I doubt BT will fix it.
1) speeds are mostly with in the poor limits
2) reduced speed nation wide puts less stress on BT's core network.
3) pancake - they don't care.
A fix will be issued in due course. The issue was unforeseen and not picked up during the trials. I believe the problem relates to DLM logic changes made at the end of last year (there will be a briefing update to ISPs next week).
Reduced speeds means less revenue from a wholesale view point.
ray_dorset
Distinguished Guru
Message 85 of 535
@-AndyH- How long is "in due course"? This year, next year?
john46
Message 86 of 535
patience is a virtue
ray_dorset
Distinguished Guru
Message 87 of 535
Time is money
-AndyH-
Expert
Message 88 of 535
I would expect within a few weeks.
But it depends on exactly where the issue lies, whether there needs to be 3rd party involvement and also the amount of testing required before a fix is issued.
OR make major changes to their FTTC network 3-4 times a year. Most of the time no one notices any changes (the DLM changes back in Nov/Dec meant the vast majority of people would not be banded).
ray_dorset
Distinguished Guru
Message 89 of 535
I would expect it next year when they start replacing devices containing the Lantiq chipset that doesn't support G.Inp.
licquorice
Message 90 of 535
Can you please post a link to a definitive statement by a technical authority that the Lantiq chipset doesn't support G.Inp.
