Sage
Message 41 of 147
Re: Gaming problems
Go here for the list of servers for COD4.
Took me less than a second to find on Google.
Message 42 of 147
Re: Gaming problems
Are they not for PC?
Message 43 of 147
Re: Gaming problems
im having the same issue however mines due to a phone line error call bt and ask them to test it.i would say por forward and the new hh5 are good options but at the moment and current state of my internet none of them made a difference to me
Message 44 of 147
Re: Gaming problems
cartergamer
Are you having a problem with FIFA or COD?
Message 45 of 147
Re: Gaming problems
yes
the issue with my internet is criticalband is being ressolved
theres a local network error at my exchange
Message 46 of 147
Re: Gaming problems
When I contacted BT just over a month ago they said they did thorough checks on my line and found nothing wrong.
Message 47 of 147
Re: Gaming problems
not sure what your problem is but mine has been confirmed as a local network error you can do you own line check by calling 150 and saying line check i think it is
Message 48 of 147
Re: Gaming problems
Will definitely give that a try, cheers mate. Did you have a problem playing FIFA or was it COD?
Message 49 of 147
Re: Gaming problems
its both i was running 78mb download 15mb upload abd around 20ms ping
now it can go down to 1mb download 0.5mb upload and over 200ms ping
sat at 30mb/d 15mb/u 200ms/p
Message 50 of 147
Re: Gaming problems
I've seen on another thread from years ago (amazingly people had a problem with FIFA 12 with BT too, I was with Sky back then so I wouldn't know,) if you connect to the BT test socket directly it eliminates any problems which may occur in terms of internal routing.
