Shetlander
Message 1 of 6
Garbage broadband speeds in Shetland yet again!
Yet again I find myself on here complaining about the garbage level of broadband speeds up here in Shetland. Its been on a go-slow all day and BT once again deny any problem exists.
Results of the latest speed test:
Ping: 1018ms
Down: 0.23Mbps
Up: 0.10Mbps
Absolute tripe. Get it sorted BT
5 REPLIES 5
Shetlander
Message 2 of 6
Re: Garbage broadband speeds in Shetland yet again!
Not interested. Quelle surprise. Standard attitude for this joke company.
Shetlander
Message 3 of 6
Latest speed test: Ping: 1360m/s
Down: 0.21Mbps
Up: 0.07Mbps
Just rubbish. Anyone from BT care to get something done about this or do I have resort to e-mailing one of your senior execs again?
Tags (1)
Shetlander
Message 4 of 6
Detailed info from the Home Hub
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 0:15:33
Downstream1,568 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)12.8 dB / 18.0 dB
Line attenuation (Down/Up)57.0 dB / 30.0 dB
Output power (Down/Up)17.3 dBm / 12.1 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)120 / 0
CRC Errors (Down/Up)0 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)0
Shetlander
Message 5 of 6
Heres the result from the bt speedtester
FAQ
Results Image not loaded
This Test comprises of Best Effort Test: -provides background information.
Download  Speed
274 Kbps
0 Kbps2000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 274 Kbps
 For your connection, the acceptable range of speeds is 400-2000 Kbps.
 Additional Information:
 Your DSL Connection Rate :1568 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 1250 Kbps
Moderator-Retired
Message 6 of 6
Hi Shetlander,
Certainly appears to be a problem here.  Your throughput speed is way below the IP profile potential.
I can see that you have emailled the Mod team already and we will be in touch soon and get this fixed for you.
Thx
Craig
BTCare Community Mod
If we have asked you to email us with your details, please make sure you are logged in to the forum, otherwise you will not be able to see our ‘Contact Us’ link within our profiles.
We are sorry but we are unable to deal with service/account queries via the private message(PM) function so please don't PM your account info, we need to deal with this via our email account :-)”
td-p/30">Ratings star on the left-hand side of the post.
