bobby67
Message 1 of 11
General broadband speed
I was wondering if someone could tell me if this is normal behaviour. I'm connected to cabinet 3 in winchburgh, West Lothian and after a recent upgrade at the exchange speeds went from around 5mb to 10mb. But I've noticed that during the evening this drops to around 2mb. Is this normal and Do I have to live with it 🤔
10 REPLIES 10
Keith_Beddoe
Message 2 of 11
Re: General broadband speed
Which BT Home hub do you have?
ADSL2+ connection speeds do not normally vary, but download speeds can be affected by line noise, or congestion.
Line noise does tend to increase in the evening, as people turn on TVs, and other electrical devices.
Is your phone line quiet?
The cabinet your line passes through has no bearing on connection speed, as ADSL2+ comes from the exchange.
bobby67
Message 3 of 11
I've got a superhub. The line has a background noise. It's not crystal clear
Keith_Beddoe
Message 4 of 11
I assume you mean the BT Home hub 6?
Please can you post the information from the home hub 6, using this link.
http://192.168.1.254/0000012803/gui/#/technicalLog/information
If you dial 17070 and select option 2, the line should be silent between announcements.
bobby67
Message 5 of 11
BT Logo BT Smart Hub Manager
Home
Advanced settings
Technical log
Information
Event log
Back
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084319+NQ62565344
Firmware version:
SG4B10002244
Firmware updated:
16-Feb-2017
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 7 Hours 52 Minutes 27 Seconds
Data rate:
1.19 kbps / 12.01 kbps
Maximum data rate:
1188 / 12268
Noise margin:
6 / 6.4
Line attenuation:
36
Signal attenuation:
175 / 360
VPI / VCI:
0/38
Modulation:
G_992_5_ANNEX_A
Latency type:
Fast Path
Data sent / received:
4 MB Uploaded / 20 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
Muirs
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
Muirs
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
90:4D:4A:37:3A:CD
Software variant:
Boot loader:
7.33.1
Webby
Message 6 of 11
Does the slowdown only happen in the evening?
bobby67
Message 7 of 11
Yes it only appears to happen in the evening. When I work from home during the day I get nearly 10mb, but in the evening it's closer to 2mb
Webby
Message 8 of 11
Can you put your number into here http://www.dslchecker.bt.com and post up the results please including the exchange name.
imjolly
Message 9 of 11
your conenction speed looks about right for your 36db attenuation  if drop off is only at night and maybe weekends sounds like congestion on your Winchburgh exchange
are you conencting with wired or wireless?
bobby67
Message 10 of 11
BT BROADBAND AVAILABILITY CHECKER
Telephone Number 015068xxxxx on Exchange WINCHBURGH is served by Cabinet 3
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 5 -- 3 to 7.5 Available -- -- -- --
WBC ADSL 2+ Annex M Up to 5 Up to 1 3 to 7.5 Available -- -- -- --
ADSL Max Up to 4 -- 2.5 to 7 Available -- -- -- --
Fixed Rate 2 -- -- Available -- -- -- --
