Message 11 of 23
Re: Getting help with packages
if you entered your phone number using link and posted results the we could see what your line is capable off and that way give an idea of suitable package
check here for hub version and then follow instructions for stats
https://kitz.co.uk/adsl/frogstats.php
Message 12 of 23
To get the stats I would have to unlock the modem and reconfigure the whole thing.  Can you just tell me the difference between BT Halo and BT fibre 2.  The halo is much more expensive but I can't see any obvious advantage.  When I go to 'upgrade broadband'  on the website it checks my package but it only gives me information on BT Halo.
Message 13 of 23
sorry I am now confused
are you already on FTTC - you have an openreach modem connected to phone socket and a BT hub connected to the modem or when you say modem do you mean separate modem or BT hub
Halo 1 or 2 is an add-on to your broadband package not an actual package on it's own
it would be far easier if you just posted the info from dslchecker link
Message 14 of 23
I have a BT modem that need to be unlocked.  This means powering down and reconfiguring the whole thing.  I used the link you gave and that's the information that came up on the page when I put in details of the hub and modem.  I will order the broadband package from the site.  If Halo is just an add on then I don't need it.  There's only me in the house.   Thank you for your help.
Message 15 of 23
to change/renew your broadband phone the options team 0800800030 and they will help you get the package that suits you  they are uk based and queues not long
I am still confused by your replies as to what package and hub you have currently
Message 16 of 23
If you are only getting 20M, changing your package is not going to improve your speed.
Message 17 of 23
No, but I'm paying a lot for my package.  I can see now why I can't order the other braodband deals.  It's because they're only available to new customers.  I think I can get a much better deal eslewhere.
Message 18 of 23
phone the number I posted you will get a better deal and the package you want  0800800030
Message 19 of 23
Tried ringing this morning but there aren't enough operators to answer the calls so I had to give up.  I'm paying nearly £55 a month so I'll check out the other providers.  My friends are all saying they pay a lot less than that.
Message 20 of 23
was it the number I posted or just the number from the website  the number I posted is for contract renewals or changes for existing customers
