roger06
Message 1 of 11
Getting slower and slower - WHY?
BT are demanding more and more money for broadband and mine's getting slower and slower.
I used to get at least 44 mb, now it's down to 31mb?
Why?
10 REPLIES 10
john46
Message 2 of 11
Re: Getting slower and slower - WHY?
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
The stats for the Home Hub 6 can be found on the Information page from http://192.168.1.254 then Advanced Settings -> Technical Log.
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
pippincp
Message 3 of 11
Why?
Can you post the connection stats from the HH?
@john46beat me to it.Smiley Very Happy
roger06
Message 4 of 11
Here you go...
1. Product name: BT Home Hub 2. Serial number: +068543+NQ42946332 3. Firmware version: Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 02/07/15 4. Board version: BT Hub 5A 5. DSL uptime: 1 days, 23:25:35 6. Data rate: 7261 / 33478 7. Maximum data rate: 7261 / 43030 8. Noise margin: 6.1 / 9.6 9. Line attenuation: 22.3 / 23.7 10. Signal attenuation: 22.1 / 21.3 11. Data sent/received: 682.8 MB / 6.6 GB 12. Broadband username: bthomehub@btbroadband.com
pippincp
Message 5 of 11
Have you been rebooting the Hub? If so stop it, it'll only make matters worse.
Try a quiet line test 17070 option 2, the line should be silent between announcements. Any noise report a line fault not a broadband one.
roger06
Message 6 of 11
What noise am I listening for? There's a continual low volume hiss.. but that could be the phone (or my ears!)
john46
Message 7 of 11
The quiet line test should be just that silent any noise will affect broadband
roger06
Message 8 of 11
Thanks. What do I do about it then? As there was definitely a continual hiss. It wasn't like I had the phone to my ear when it's not making a call.
pippincp
Message 9 of 11
Report a line fault on 151. Don't mention broadband.
DavidM
Moderator
Moderator
Message 10 of 11
Hi @roger06 and thanks for posting.
If you have noise on the line you need to report a line fault to 151 for investigation. Once that's sorted the broadband connection will recover automatically.
@pippincp beat me to it Smiley Very Happy
Cheers
David
