Solved! Go to Solution.
There is no switch to go from 100mb to 1gb. Are you sure your devices all have 1gb network cards
You misunderstood. There is no switch setting in the hh
I can only guess that something in the network has auto-negotiated the speed down to 100M. That might be because the cabling isn't good enough for 1G, or perhaps it's just a subtle incompatibility between two bits of hardware.
