Recognised Expert
Message 11 of 21
Re: Gigabit speeds hh5
@yan101 said "Best i can get is 11MB/s which suggests its only doing 100mbps"
What do you see as the port speed as indicated by the hub? From the hub (http://192.168.1.254) go to Advanced Settings -> Home Network -> Devices and you'll see the speed indicated under the Wired Connections section immediately under the graphic of the hub.
Also the GS105 has two LEDs per port, with only the left hand one being lit if the port is operating at 100 Mbps or both being lit if running at 1000 Mbps. How many do you see lit?
Have you tried different ports on the hub and different ports on the Netgear switches?
Regards
Message 12 of 21
Hub is showing 1gbps. Both lights on both switches show 1gbps ( 2 lights lit) tried different ports yea.
Message 13 of 21
Also showing 1gbps in network settings on both pc's
Recognised Expert
Message 14 of 21
That would suggest the ports are running at 1 Gbps to me Smiley Very Happy
Where do you see the 11MB/s?
Can you download a program called iperf (https://iperf.fr/iperf-download.php#windows) and test with that? You run it from the command line with one PC as the receiver and the other as the sender. The receiver you enter iperf3 -s, and on the sender you enter iperf3 -c <ip_addr_of_receiver>.
Here's an example of the results you should see:
C:\Users\smf22\Downloads>iperf3 -c 192.168.1.97
Connecting to host 192.168.1.97, port 5201
[  4] local 192.168.1.78 port 4905 connected to 192.168.1.97 port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec   108 MBytes   904 Mbits/sec
[  4]   1.00-2.00   sec  93.4 MBytes   782 Mbits/sec
[  4]   2.00-3.00   sec   101 MBytes   847 Mbits/sec
[  4]   3.00-4.00   sec   110 MBytes   923 Mbits/sec
[  4]   4.00-5.00   sec   111 MBytes   931 Mbits/sec
[  4]   5.00-6.00   sec   111 MBytes   935 Mbits/sec
[  4]   6.00-7.01   sec   104 MBytes   865 Mbits/sec
[  4]   7.01-8.00   sec  98.6 MBytes   836 Mbits/sec
[  4]   8.00-9.00   sec   111 MBytes   931 Mbits/sec
[  4]   9.00-10.00  sec   111 MBytes   933 Mbits/sec
[  4]   0.00-10.00  sec  1.03 GBytes   889 Mbits/sec                  sender
[  4]   0.00-10.00  sec  1.03 GBytes   889 Mbits/sec                  receiver
iperf Done.
Regards
Message 15 of 21
11MB/s is when im transfering a file from one pc to the other. Ill download iperf now and post results
Message 16 of 21
C:\WINDOWS\system32>iperf3 -c 192.168.1.67
Connecting to host 192.168.1.67, port 5201
[ 4] local 192.168.1.72 port 50862 connected to 192.168.1.67 port 5201
[ 4] 0.00-1.00 sec 7.00 MBytes 58.7 Mbits/sec
[ 4] 1.00-2.00 sec 9.50 MBytes 79.6 Mbits/sec
[ 4] 2.00-3.00 sec 10.1 MBytes 85.0 Mbits/sec
[ 4] 3.00-4.00 sec 10.4 MBytes 86.9 Mbits/sec
[ 4] 4.00-5.00 sec 10.1 MBytes 84.9 Mbits/sec
[ 4] 5.00-6.00 sec 9.62 MBytes 80.9 Mbits/sec
[ 4] 6.00-7.00 sec 10.4 MBytes 86.9 Mbits/sec
[ 4] 7.00-8.00 sec 11.2 MBytes 94.5 Mbits/sec
[ 4] 8.00-9.00 sec 11.8 MBytes 98.5 Mbits/sec
[ 4] 9.00-10.00 sec 9.88 MBytes 82.9 Mbits/sec
[ 4] 0.00-10.00 sec 100 MBytes 83.9 Mbits/sec sender
[ 4] 0.00-10.00 sec 100 MBytes 83.8 Mbits/sec receiver
Recognised Expert
Message 17 of 21
Hmm. Well either the Home Hub (HH) or the Netgear switch is lying.
Can you reconnect the PCs, first both to the HH and then both to the Netgear switch, and check each time whether you get GE speeds.
Regards
Message 18 of 21
Im just in the process of changing the network card in the pc upstairs. Its a qualcomm atheros and there arent any windows 10 drivers for it. So im wondering if thats the issue. Ill change the card and call the cables. If that dosent work then ill do as you said.
Message 19 of 21
It was the ethernet adapter in the pc. No driver for windows 10. So it showed as 1gbps but wasnt working. Got a new one and its working.
Recognised Expert
Message 20 of 21
Good news Smiley Happy
