Message 1 of 12
Gigabit speeds
Hi Folks
Quick Q if I can... I'm not getting gigabit speeds to a hardwired laptop... I think I have tracked the problem down to the last cable in the chain... (the path from the router is cable from switch to wall socket, internal cable from socket to another socket and finally the cable from socket to laptop that I seem to think is dodgy.
I've plugged a patch cable into the last socket to the laptop and get 1Gb speed hence thinking its that last cable.  It is a piece of maybe 10m cable that I have made myself by putting connectors on using the same cat5e cable I have used elsewhere to network the house over which I don't seem to have any other problems... I have checked the cable with my continuity tester and it says it's fine...
What could the problem be?
11 REPLIES 11
Message 2 of 12
Re: Gigabit speeds
When you say switch I assume you mean an un-managed one, are you sure that is gigabit? some are only 10/100 Mb/s
Message 3 of 12
Re: Gigabit speeds
Hi there!  Yes its a gigabit unmanaged switch (TP Link TL-SG1024D).  I get gigabit speed on all connections currently barring the one that I mentioned.
Message 4 of 12
Re: Gigabit speeds
Does the laptop have a gigabit network card?
Message 5 of 12
Re: Gigabit speeds
yup 🙂
Message 6 of 12
Re: Gigabit speeds
Oh... How close to vmax are you getting? I'd expect some drop off due to bottlenecks in the system though.
Message 7 of 12
Re: Gigabit speeds
Is the laptop connected to port 16 by any chance? see below
 https://static.tp-link.com/2020/202007/20200706/7106508931_UnmanagedEasy%20Smart%20Rackmountable%20S...
Message 8 of 12
Re: Gigabit speeds
Hi... no not connected to port 16 🤔
Message 9 of 12
Re: Gigabit speeds
Are you sure all 8 wires are firmly terminated. GbE requires all 8 wires but 100M only needs 4.
Message 10 of 12
Re: Gigabit speeds
I can only think this must be it... although I've continuity tested the cable and that says it's ok.
Perhaps I should try redoing the plugs?
