oakserver
Message 1 of 2
Google Wifi with BT Parental Controls
Hi
I'm an early Adoptor of Google Wifi but found you cannot set up the additional wifi point without switing off BT parental controls. The app just says checking network forever. If I turn off to install it works.
But as soon as I turn on parental control again the additional wifi point loses connection.
It's quite annoying. I've logged a ticket with Google but wonder if anyone else has seen this issue perhaps in trailing?
Tags (1)
1 REPLY 1
john46
Message 2 of 2
Re: Google Wifi with BT Parental Controls
The Goggle Wi-Fi will be using their own DNS and parental controls will block that DNS as it only allows the use of BT's DNS's
