I realise this has been discussed before but I can't actually find a solution, despite the posts saying the issue has been resolved.
I cannot search Google, Google maps or access GMail via Samsung mobile devices (tablet or phone) and wifi. I've been on to customer services (chat and telephone) on numerous occasions and finally was told that it was a problem with Google. I never had a problem with my previous service provider so I don't understand how this could be the case. Google have told me the same things that BT have told me (factory reset, etc, etc) and seem to think its a BT problem. Everything works fine on my phone via 4G so I can't see how its a problem with Google but I'll keep an open mind as its far too easy to blame BT at this point.
I've tried all the suggestions on the forum so far other than VPN or buying another modem/router. Btw, the laptop works fine via wifi or wired and the Samsung TV works fine, although I've had to wire the connection as Samsung Tvs aren't great at picking up faster braodband speeds. Apparently.
Any help would be greatly appreciated.
Many thanks BB
If laptop is working fine both wired and wireless then we can probably assume your connection is working fine. No problems here with wireless PCs, laptops, tablets or phones. Google maps work fine on phones and tablets, email looks fine as well, can reach the Gmail site and the BT webmail.
If the 4G connection shows everything functioning correctly then the only thing I can see that's different in your network is the Hub. I don't use a Hub and never have, other than the two occasions the engineer was here, first to install the line and check the ADSL years back and when Infinity was installed. Soon as they left the Hub was removed and my own kit put in place. So you might want to try a third party VDSL modem/router, TP-Link have some quite reasonably priced devices.
same problem here
ca not not use any google apps (or any apps) on wifi on bt home hub
can use browser on my s7 edge phone though. wifi works everywhere but not at home
same with laptop and google websites. had to turn of ipv6 on laptop to get google websites working on ethernet and wifi
bt has no solution and it started all of a sudden 4 weeks ago
also bought a new none bt hub
it also doesn't work.
had 2 home hub 6s and a 5. none work
You might try using different DNS servers in your third party router.
OpenDNS Servers:
IPv4
208.67.220.220
208.67.222.222
IPv6
2620:0:ccc::2
2620:0:ccd::2
Thanks for the advice. Really appreciate it. It seems like a different router may be the answer but it doesn't solve the problem that we can't access Google sites through BT Hub. Surely this is something basic for BT to sort out?
I am not convinced the Hub is your problem. I use the Hub 6 and have no difficulty in accessing the Google sites you mention on a Samsung tablet. I wouldn't rush out and buy a new router.
Yes, I admit it seems odd.
What happens if you use the OpenDNS servers in your devices advanced settings? Though the Android devices seem to default to Google's DNS servers so there theoretically shouldn't be an issue.
BT aren't actually blocking sites and we're not seeing lots of people with your problem so not likely to be the Hub either or more would have the same problem. On checking again with Samsung phones and Toshiba tablets everything works as normal, mail, Google search etc.
I'll try the advice posted here and thank you everyone for responding.
I'm wondering if its worth contacting Samsung as, reading about it here, it only seems to affect Samsung products.
It's just frustrating when I didn't have a problem with my previous ISP and have no problem on anyone elses home wifi but my own (no-one has BT so I can't try it anywhere else).
