Message 1 of 3
Got BT900 today and have poor wifi generally outside of the router area, advice on Cat 7 please...?
Media server will be in a room upstairs, looking to hardwire that in using an external cable from the living room to the outside and up under the guttering etc down into the room it's in.  I then have a PS5 in the living room which will also be hardwired into the router.  This allows me to stream etc easily.  I'm looking for cable suggestions though, should I look at Cat 7?  Any good external ones someone can recommend?
Cheers!!
2 REPLIES 2
Message 2 of 3
Re: Got BT900 today and have poor wifi generally outside of the router area, advice on Cat 7 please.
CAT7 is more than enough for your needs. Here's a comparison chart.
2021-04-24 00_44_12-(15) CAT 8 vs CAT 7 Ethernet Cables - Is there a difference_ - YouTube — Mozilla.png
All external cables have to meet the same minimum specs but if you want to go premium search for "Kenable external shielded CAT7 Outdoor Use COPPER Ethernet Cable SF/FTP Reel 50m Black" or find a supplier that makes pre-terminated lengths..
Hope this helps.
Message 3 of 3
Thank you!
