Message 1 of 23
Got Infinity 2 on 3rd Sept still very slow
Got Infinity 2 on 3rd Sept, sub contractor cocked up , had Openreach in they have fixed phone line, been on phone to BT lady she suggested switch off all other devices and connect via ethernet cable to get a decent speed!
isn't that defeating the object, I mean why don't they reccomend you pitch a tent next to the BT cabinet and connect directly in there
why isn't this plug and go?
22 REPLIES 22
Message 2 of 23
Re: Got Infinity 2 on 3rd Sept still very slow
i should say am using the BT infinity homehub they sent
Message 3 of 23
if there is a UK based tech number that BT have I can ring then please share it as I can't see anything on the website
Message 4 of 23
there is no uk CS number just the standard
08001114567
can you got hub manager the troubeshooting then helpdesk and post stats 1-12.  run btspeedtester and when first test completes then run diagnostic test and post results
btspeedtester
enter your phone number and post results remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
Message 5 of 23
ok will give that a go, apparently BT have widespread problems today anyhow
Message 6 of 23
oh wow! not sure whether I should be doing any of that stuff, what could possibly be wrong ?  i have a very new Sony laptop which is very fast, a home hub that BT sent and the fastest (allegedly) connection that BT do, how can it be wrong
Expert
Message 7 of 23
It's very hard to make a comment unless we know what speed you are getting and what speed you are supposed to have. It would be helpful if you did what imjolly has sugested. Thanks
Message 8 of 23
No ISP guarantees wireless speeds or connections due to external interference sources BT will only accept speed problems if carried out with a wired connection
Message 9 of 23
can't BT have tech guys who log in to your router, BT Infinity 2 is now looking a very expensive waste of time, do the BT ads show everyone with connecting ethernet cables into the hub?
Expert
Message 10 of 23
It will only be an expensive waste of time if you are not prepared to try and get the issue resolved.
There are plenty of people on this forum who may be able to help you, but you need to give them help in order so they can help you
