pbwpu
Message 1 of 14
Grey Box
Out of curiosity anyone know what this is. I have a grey BT branded box immediately before my master sockets (2) its oblong but also slightly triangular with a piece of string/cord coming from the front to the bottom.
13 REPLIES 13
imjolly
Message 2 of 14
Re: Grey Box
Picture?
pbwpu
Message 3 of 14
Re: Grey Box
john46
Message 4 of 14
Re: Grey Box
that is normally used as an external connection box
pbwpu
Message 5 of 14
Re: Grey Box
"that is normally used as an external connection box "
Normally as in normally internally before the master in a typical property? Never had this in my previous properties.
john46
Message 6 of 14
Re: Grey Box
no it is often used on the outside of properties hence the word external
pbwpu
Message 7 of 14
Re: Grey Box
Ok thanks, I wondered if you meant that but it didn't look very obviously waterproof. Looks like a relic from the 1970s tbh
imjolly
Message 8 of 14
Re: Grey Box
the external grey box looks like this and not like yours  external_NTE_1.png  this is a master socket usually outside the back door
iniltous
Recognised Expert
Message 9 of 14
Re: Grey Box
Looks like a BT66 (block terminal 66), usually fitted externally and used as the transition point between an underground cable and 'internal' type wiring..it is common though that a cable coming out of the BT 66 would terminate at the NTE5 master socket
I think the 'bit of string' is a retaining strap for the lid, so it doesn't get lost
imjolly
Message 10 of 14
Re: Grey Box
do you have 2 master sockets?  do you mean one actual master and and other NTE5 used as an extension socket?
