pjm0512
Message 1 of 4
Grey box next to PCP
Hi everyone, sorry if this is a bit of a weird question but here goes...
There's an oldish PCP in my area that has a grey pole of about the same height as the PCP. I thought it could be a capped off lamppost but I don't think so. I was wondering whether it has anything to do with BT, and if not whether anyone could shine some light on it.
3 REPLIES 3
pjm0512
Message 2 of 4
Re: Grey box next to PCP
In fact to my eyes on the second picture it looks like the generic BT logo without any piper/globe.
iniltous
Recognised Expert
Message 3 of 4
SCP, secondary cross connection point , a flexibility point that sits between a PCP and DP in the external network architecture , not every DP is fed from a SCP most are fed from a PCP, lots of them are not used as a flexibility points anymore, they are 'cut out'  the incoming cable is permently connected to the outgoing cable (connected straight through)
I would think it's unusual for a SCP so close to a PCP
pjm0512
Message 4 of 4
Thanks very much :).
