Brianl1964
Message 1 of 3
H2 Channel
Does anyone else have a problem with the H2 channel?
This breaks up after it's been on a for a short time and shows IPC6023 of which does not appear on other channels, can anyone help.
2 REPLIES 2
Leebool
Message 2 of 3
Re: H2 Channel
I have a sound problem on the H2 channel. The audio breaks up regularly and you can't understand any dialogue.
dfel100
Message 3 of 3
Re: H2 Channel
I think this was on the forum a little while ago.  I think the (short term) remedy was to pause H2 for a couple of seconds and then press play.  I think they said there was a software fix that was currently being tested, but no estimated date of when that would be available, it is a known problem.
