Keith_Beddoe
Message 21 of 132
Re: HD Signal Strength and Quality Issue
@glenhill68 wrote:
Thanks. Are you fairly confident the attenuator will do the trick and reduce my signal strength from 100%?
I would be very surprised if it did not, as 6dB is normally enough to bring the input signal within acceptable range.
I cannot think of an occasion where 12dB has been needed. I used to use a selection of attenuators on the old analogue TV system, to help with aerial alignment. It not really possible on digital, as the signal does not degrade, it just stops Smiley Wink
Aerial installers use signal strength meters.
glenhill68
Expert
Message 22 of 132
Thanks for all your help.
It should be delivered Friday or Saturday so will update you then.
glenhill68
Expert
Message 23 of 132
Hi Keith,
I got the attenuator today and fitted it to the youview box. I returned the channels and the signal strength ranges between 95-97. It does still drop to zero and picture breaks up but not so often
I had two regions to choose from after returning.
Any ideas please?
Keith_Beddoe
Message 24 of 132
Its possible you need additional attenuation, as you must have a very strong signal coming down your aerial. You could either add an additional 6dB attenuator, or fit a 12dB attenuator instead (neater).
95-97% is still too strong.
If you have a local Maplin Electronics store, you can normally pick one up there. They also do a variable aerial attenuator for £4.99, which may be a better option, as you can fine tune the signal level until the optimum level is found.
The fact you can now see two regions, shows that the overloading has reduced.
glenhill68
Expert
Message 25 of 132
I have just ordered a 12db from ebay as cheaper than Maplin.
It is still as bad as before.
glenhill68
Expert
Message 26 of 132
If I get time tomorrow I will try Maplin
Keith_Beddoe
Message 27 of 132
Do you know how far away you are from the transmitter?
glenhill68
Expert
Message 28 of 132
I don;t know which transmitter the aerial points to. I would guess probably elmley moor in Huddersfield which by road is 53 miles
glenhill68
Expert
Message 29 of 132
It is as bad as before with the pic breaking up every few seconds, unwatchable on HD channels again.
Keith_Beddoe
Message 30 of 132
If the quality is still showing 100%, then its got to be too much signal. I am surprised that you do not get issues on any of the other TVs connected to the amplifier.
Really bad aerial alignment could cause issues, but the signal quality would be low.
I cannot suggest anything else apart from trying a variable attenuator to get the signal level down to about 70%.
Elmley Moor is going to be much closer line-of-sight, and if they have recently increased the transmitter power level, then that would explain why the problem has just started.
Its a pity the amplifier has not got a variable gain control on it.
