Keith_Beddoe
Message 61 of 132
Re: HD Signal Strength and Quality Issue
@glenhill68 wrote:
Ignore that link, no stock. Will try variable attenuator first then look at new amplifier, that one you mention is £11 on Amazon.
It does not have a 4G filter, and you do not need a digital bypass, as that is for Sky satellite systems.
The Amazon one should be fine, but you may still need the attenuator if the output level is too much.
As you have said, try the attenuator first.
glenhill68
Expert
Message 62 of 132
Any good   SLx 8-Way Distribution Amplifier
glenhill68
Expert
Message 63 of 132
Just ordered the variable attenuator bcaa and female connector from maplin to collect for £7
Keith_Beddoe
Message 64 of 132
That should be fine, as it includes a 4G filter, its the same make as the Amazon one but it has rather a lot of signal gain, and far more outputs than you need. Try the attenuator first.
PS, Its best not to post direct links to e-commerce sites, just the description of the item, and where it come from.
glenhill68
Expert
Message 65 of 132
Ok, noted.
Will go for the Amazon one you suggested if needed.
Keith_Beddoe
Message 66 of 132
The connector is always useful to have for fault finding, as you can temporarily bypass the amplifier, just in case that is making matters worse.
Plenty of things to try over the weekend Smiley Wink
Keith_Beddoe
Message 67 of 132
@glenhill68 wrote:
Ok, noted.
It would bring your system up-to-date, as you no longer need VHF features, that was a very long time ago.
https://en.wikipedia.org/wiki/405-line_television_system
glenhill68
Expert
Message 68 of 132
It is on my Amazon wishlist so will order in the next week or so. As you say, it's needs updating.
Going to pick up the variable attenuator in the next couple of hours so will try that first then the female connection if still not good.
glenhill68
Expert
Message 69 of 132
Just collected the variable attenuator. Will be home in half an hour for the moment of truth.
glenhill68
Expert
Message 70 of 132
It's made no difference, change strength to 80, 70 and in the 60s too.
