Message 1 of 21
HD issues with you view box
Hi. I have fibre broadband and BT vision with a youview box. Everything has been fine for months. Now all of a sudden my HD channels are freezing and pixelating. Really annoying. Any advice???
20 REPLIES 20
Recognised Expert
Message 2 of 21
Re: HD issues with you view box
How is your box connected to the Hub?
Message 3 of 21
Hello. It is connected via Ethernet cable direct from my hub 5
Recognised Expert
Message 4 of 21
Is it the Freeview HD channels or the Extra Channels in HD? What's your current line speed?
Message 5 of 21
Download is 50 meg. Upload 8. Itv, bbc1 and 2 channel 4 and 5 HD channels.
Moderator
Moderator
Message 6 of 21
@Ryanharvey These problems are normally caused by broadband connection speed issues. Try these checks and let me know how you get on.
Message 7 of 21
Currently running at 56 meg. Turned everything off as advised. Didn't do it for a while but has started pixelating again.
Moderator
Moderator
Message 8 of 21
Thanks for trying that @Ryanharvey. I think we'll need to take a closer look at this for you so can you send over the details? You'll get the contact the moderators link in my profile.
Cheers
David
Message 9 of 21
Thanks David. What do I need to do now? I've clicked your profile but can't find the contact moderators link?
Message 10 of 21
Found it and sent it. Thanks again
