dansam
Newbie
Message 11 of 15
Re: HELP.....BT sports on BT Vision
Thats just great.............17 days to get it working is unbelievable.....................
magpie0722
Newbie
Message 12 of 15
Hi dansam
check your E mail from BT confirming your order, did it specify BT Sport Package on it, if not you have to order it seperately. i was in the same boat, spent hours on phone to India, useless. now sorted ring Newcastle. 0800 731 0286 they will help.
dansam
Newbie
Message 13 of 15
Thanks for the number.. pressing the keypad as i write.........
Hunter2660
Recognised Expert
Message 14 of 15
BT Sports 1 & 2 and ESPN  should be showing in your entitlements. As they're not that's the problem. Point that out when you get through and it should be easy to rectify.
dansam
Newbie
Message 15 of 15
Thanks for the info.. still trying to get through ......
