Newbie
Message 1 of 7
HELP - Broadband speed drops with Home Hub 3.0
HELP! - Firstly I apologise, this is going to be a long post.
I originally registered a fault on 4/5/11 (it's now 19/9/11 and it hasn't been resolved). I'm completely at my wits end, which is why I’ve resorted to a forum post. I have tried going through your call centre several times and whilst your staff are courteous they repeat the same scripted tests. When I asked to speak to a product specialist/technician I was told it would take 4 days to arrange a phone call. I then tried the email feedback, which I got an email back from, however I couldn't email the person back directly to progress any further actions.. Only to be hung up on when I rang and asked for my ticket to be re-opened! I have never been so outraged in my life!
So now the rant is over here's my problem (ref:110914-009151)
I have been trying to resolve an internet connectivity issue with you for 4 months. Initially it was thought to be an issue with the Video On Demand service freezing, however it became apparent that there is a problem somewhere else that causes connectivity issues (interestingly my upload speed doesn't change, nor do any of the lights change on the hub3.0 equipment). I have connected the home hub to the master socket and still have the same connectivity issues (where the connection will drop from 12mg to 0.2mg). I have had internet to my apartment for 4 years and have previously had no problems. There has been no building work, no internal property alterations. The first engineer that came to the property changed all BT equipment (my beloved home hub 2.0)
6 REPLIES 6
Newbie
Message 2 of 7
Re: HELP - Broadband speed drops with Home Hub 3.0
Below is a log of download/upload speeds. Whilst I appreciate that the actual results may differ, however it is the dramatic inconsistency which is the issue.
Download speed (kbps)
Upload Speed (kbps)
Date (YYYY-MM-DD)
Time (hh:mm)
12251
569
31/08/2011
19:54
8446
580
31/08/2011
19:55
1655
915
31/08/2011
19:56
6553
913
31/08/2011
20:18
992
917
31/08/2011
20:20
1198
893
31/08/2011
20:20
3719
918
31/08/2011
20:23
2064
916
31/08/2011
20:24
2589
918
31/08/2011
20:25
12252
927
12/09/2011
18:28
12253
567
12/09/2011
18:30
12255
923
12/09/2011
18:33
12255
927
12/09/2011
18:34
12325
919
12/09/2011
18:36
12246
582
12/09/2011
18:42
12228
923
12/09/2011
18:47
7504
924
12/09/2011
18:49
649
811
12/09/2011
19:03
9063
951
13/09/2011
21:13
9263
952
13/09/2011
21:13
2845
936
13/09/2011
21:15
1853
928
13/09/2011
21:16
8254
935
13/09/2011
21:17
2567
910
13/09/2011
21:17
4038
913
13/09/2011
21:20
2029
907
13/09/2011
21:20
9068
939
13/09/2011
21:21
3014
922
13/09/2011
21:21
1010
348
23/08/2011
01:48
1003
298
25/08/2011
23:13
979
320
25/08/2011
23:39
799
204
11/09/2011
20:06
980
321
13/09/2011
19:54
205
93
14/09/2011
20:44
12237
896
15/09/2011
21:41
10867
892
15/09/2011
21:42
7905
884
15/09/2011
21:43
9527
899
15/09/2011
21:44
8517
551
15/09/2011
21:45
10683
893
15/09/2011
21:46
10861
560
15/09/2011
21:47
4113
895
15/09/2011
21:49
9280
890
15/09/2011
21:51
10856
891
15/09/2011
21:52
8811
601
15/09/2011
21:54
8471
904
15/09/2011
21:55
1533
881
15/09/2011
21:57
3534
869
15/09/2011
21:58
1889
890
15/09/2011
21:58
5116
882
15/09/2011
21:59
Message 3 of 7
Hi baggers, I'm not the expert but I have had similar problems with my new HH3.
I think you are assuming (as I also did and I would say it's natural) that the modem will try it's best bit rate connection every time you switch it on / reset it.
My latest conclusion is that with HH3 they tried to be smart and guess the "best" rate for the specific line, i.e. sacrifice some speed for a stable / less errors link and perhaps while minimising the output power.
I also found that the older modem used to connect to a higher rate, but in the end after patience to leave it on for about a week it came close to the old router and I suppose the end result is about the same. I could probably be in a higher 250 step IP profile, but this is what I lost.
This is why they insist on leaving the equipment on the longest possible. Do you have problems if you leave it find it's best rate? I can see from your statistics that when you left it from 31.08 to 12.09 it switched back to 12k.
It might be that you are upset because HH2 used to connect at a slightly higher speed, understandably, but maybe the IP profile (capping your real speed) was about the same.
My 2 cents,
Adrian
Message 4 of 7
@baggers
this is a community forum where customers help customers and the only BT employees are the mods.
in order for the forum members to offer assistance please can you post the adsl stats from your router may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z, if netgear enter 192.168.0.1) and run btspeedtester (MAC users may have problems) http://speedtester.bt.com or http://bt.custhelp.com/app/answers/detail/a_id/9354/c/346,4740,5520 and post the results .
Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem  I appreciate you may have gone through all this before but the information will help especially if you need to get mod assistance
Newbie
Message 5 of 7
hi adsp40,
i forgot to mention that the changes in speed coincide with "hard re-boots" (removing the power cable). Doesn't always work though.
I changed the wirless to g/b (even though my laptop has an N rated wireless adaptor).
Chose a manual channel (6) to stop the hub switching channels on me.
Newbie
Message 6 of 7
Hi Imjolly,
Thanks for the advice:
ADSL Line StatusConnection InformationLine state: Connected
Connection time: 1 days, 11:46:21
Downstream: 14 Mbps
Upstream: 1.188 Mbps
ADSL SettingsVPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.5 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 8.5 dB / 6.6 dB
Line attenuation (Down/Up): 15.6 dB / 7.7 dB
Output power (Down/Up): 16.1 dBm / 12.0 dBm
FEC Events (Down/Up): 27393230 / 0
CRC Events (Down/Up): 637779 / 54
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
HEC Events (Down/Up): 1443115 / 57
Error Seconds (Local/Remote): 20616 / 39
Message 7 of 7
Hi
Could you please also post the results in full of the Bt speed test and also what were the results of the quiet line test please once wehave them we can help further
You also say you have changed the wireless channel you could still be suffering wireless interference I suggest downloading small programme Insidder running it and making sure you are intact on a clear channel some of the problem could be from another router on thesame channel try and select either a free channel or one with a very weak signal on
Wireless interference. Would certainly cause speed problems
