RDowson
Message 1 of 6
HG612 with Apple AirPort Extreme
I was having loads of wifi issues with the Home Hub 5 so I bought an Apple AirPort Extreme which fixed the issue.
I have today recieved an Huawei HG612 3B modem to use with PPPoE to the AirPort Extreme.
I have noticed that speed tests are showing a slower speed (both wired and wireless).
Is there any reason for this?
5 REPLIES 5
RDowson
Message 2 of 6
Re: HG612 with Apple AirPort Extreme
I'm on Infinity 2 but my speeds are close to Infinity 1. Has this caused the profile to change?
Sage
Message 3 of 6
Unless you post a result of the further diagnostics test how can we tell?
RDowson
Message 4 of 6
I've gone back to the Home Hub 5 now and the speeds have increased again.
The upload is syncing at 19Mbps but the upload is now at 71Mbps rather than the usual 76Mbps.
Will this increase again on it's own? Should I reboot later tonight at a quieter time?
Sage
Message 5 of 6
Just leave it and it sholud recover again.
RDowson
Message 6 of 6
How does that happen? Doesn't it need to resync to gain more speed? Will it do that itself?
