Message 1 of 36
HH 5 Replacement !!!!!
Hi Everyone -
I cant see any solution to my problem of OpenRG with HH5 so.. would the -
ASUS DSL-N66U Wireless Router - N900, Dual Band be the one to replace it with?
My current HH plugs into the new faceplate that BT fitted no other hardware was installed
if you can help me then please do!!!
thanks & regards
Martin.
Tags (1)
35 REPLIES 35
Expert
Message 2 of 36
Re: HH 5 Replacement !!!!!
I have one but it suffers LCP drops as does the HH5 used on it's own, so it might be an expensive waste of time to be honest.
I have an unlocked HG612 and have used that withthe HH5 without issue and I'm loathe to say this (tempting fate!) but after reading some other posts in here regarding success with the ECI modem and HH5 I put it back on and it's still going strong after 2 days. I had tried this before and it suffered PPP LCP drops constantly, no idea why it seems stable now and the HH5 on it's own isn't.
Not tried the DSL-N66U for over a week but I do know it was syncing at lower speeds than the HH5 although there is a way to get an increase through telnet at the moment. Asus customer support have told me this function will be written into the GUI at the next firmware revision.
For the time being it might be worth just getting an ECI modem or maybe a HG612 from a well know auction site and connecting that up to the HH5.
Message 3 of 36
Hi..
How would you setup the HG612? piggy back the HH5 ?
thanks
Martin
Distinguished Expert
Message 4 of 36
Yeah, plug the phoneline into the HG612 and plug LAN1 of the HG612 into the WAN on the HH5.
To say thanks for a helpful answer, please click the white star
Message 5 of 36
thanks for the info.. I downloaded the manual last night - and after reading a few pages!
do you know if there is a "how-to-setup" Smiley Happy
thanks & regards
Martin..
Message 6 of 36
Message 7 of 36
So is the unit a simply plug-n-play you dont to setup the ip or dns or vpn's?
if you look at the manual you woundn't think so!
thanks & regards
Martin
Message 8 of 36
The Openreach modem is a simple plug and play unit. If you use a non BT router you will need to set up the router as
PPPoE,  Username bthomehub@btbroadband.com and the password if the router ask for one, can be anything such as BT.
Message 9 of 36
some good news at long last! - I thought I would be trying to set it up!! Smiley Frustrated I just hope it will
sort out the current problems I have with HH5 - thanks for inoformation!
thanks & regards
Martin.
Expert
Message 10 of 36
"Instruction manal" ?
Oh ,if its one of those unlocked HG612's , I think they also just plug the same way as normal ones and you can plug in lan2 to a spare  ethernet port for line info.
