daleski75
Message 1 of 6
HH2 - Keeps resetting itself to factory defaults?
Hi Guys,
Mine has done this twice now in a very short space of time is this a known issue with the Type A ones?
5 REPLIES 5
daleski75
Message 2 of 6
Re: HH2 - Keeps resetting itself to factory defaults?
No one?
Three times now 😞
Distinguished Guru
Message 3 of 6
If it's resetting to default without you doing owt, it must be faulty
You could try calling the BTIndia division - 08001114567 - advising them that it keeps doing this.
Hopefully after talking for x mins/hours, they'll hopefully send a replacementSmiley Wink
-+-No longer a forum member-+-
daleski75
Message 4 of 6
Yeah that's precisely what is happening, getting random lock ups and resets itself to factory defaults so I have to keep reloading the saved backup to it.
Time to explain this to BT India yay!
H_Dawg
Message 5 of 6
May the force be with you.
daleski75
Message 6 of 6
Called... explained... they ordered a new HH2 for me which was quite painless so hopefully this one will be more reliable.
