meaga-byte
Message 1 of 7
HH3 Connection stats?
This might be a really silly question but i have looked high and low for the connection stats of my new HH3
Where do i find the infomation regarding lines speed, attenuation, noise margin and crc errors etc?
Or is this kept on the modem and if so how do i access the modem lol
_______________________________________________________
If I've helped, just click the Star - Every little bit helps 🙂
If you can't fix it with a hammer, you've got an electrical problem.
6 REPLIES 6
j-whitney
Message 2 of 7
Re: HH3 Connection stats?
Do you have BT infinity? or normal ADSL?
meaga-byte
Message 3 of 7
hehe sorry, Infinity 😄
Hence i suspect its the modem 😞
Just me or is it typical BT to stop the end user from seeing there stats
just so when we are told to "turn it off and on again" we cant argue lol
j-whitney
Message 4 of 7
ha ha I don't know much about infinity but I don't think there is anyway of seeing your stats, sorry (best wait and see of someone who knows a little more than me replies)
hamish72
Recognised Expert
Message 5 of 7
The modem being separate means the hub can not access stats
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
j-whitney
Message 6 of 7
Smiley Very Happy Thought I was right Smiley Happy
meaga-byte
Message 7 of 7
oh **bleep**, so does that mean i cannot check my line speed bar doing a internet test.
Soo how does one check line atenuation or noise margin?
