milbo91
Newbie
Message 1 of 2
HH3 Help
Hi all
New to all this but I need a bit of help if you can.
I own a Belkin wireless router which I need to connect to my setup rather than the HH3 because the Belkin has two wireless networks within it self. But when I connected the Belkin to the modem it seemed not to work. Am I doing anything wrong. The BT is infinity upto 80meg getting 67 on good days
Thanks all
David
1 REPLY 1
Message 2 of 2
Re: HH3 Help
Does the Belkin have a WAN interface, and does it support PPPoE?
If not, then its not going to work.
If it supports PPPoE, then you will need to enter a user name and password.
Infinity uses PPPoE. (Point To Point Protocol Over Ethernet)
If you use a different router with Infinity, then you need to make sure that the authentication is set to PPPoE.
You can use a user name of broadbanduser@btbroadband.com and a password of bt
MTU Size: no 1492
