spendleb
Message 1 of 2
HH3 & Skype ??
Installed the HH3 last week and now I can't connect to Skype, it doesn't work on my laptop and advises there is a connection issue and check your network settings and the same on my IPOD Touch so it can't be the virus software on the laptop?    Any ideas on what might cause such an issue?    All my other internet stuff works fine.
1 REPLY 1
syops
Recognised Expert
Message 2 of 2
Re: HH3 & Skype ??
do these devices see the new ssid of the network and have these devices been set with the new password? If so try changing the wifi channel on the HH3, as your current one may be getting interference.
http://192.168.1.254/
Check your exchange or major service outages
If someone has given a helpful answer, please click on their Ratings star on the left-hand side. 🙂 ***
