Message 1 of 15
HH3 and BT WIFI/FON
Why is it when I log on to my HH3 it says this service is not activated? When i click activate not and check my status it says im activated for this service, and yes i do use it and it also says no minutes used??
Any ideas? just curious.
14 REPLIES 14
Distinguished Guru
Message 2 of 15
Re: HH3 and BT WIFI/FON
Is your hub radiating the BT WIFI SSID?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 15
No it is not? How do i make it do this?
Message 4 of 15
check your status here  https://www.bt.com/wifi/secure/status.do?s_cid=con_FURL_btfon/status
Message 5 of 15
Yeah ive done that imjolly, it says im active. I use it when out also by logging in. Just find it strange hub says not active and i dont think my hub is transmitting an open signal. Not sure though. The ones i pick up are very weak.
Message 6 of 15
if you have a wireless pc or laptop with windows you can try downloading inssider2.2 (istumbler if MAC) and then run it. This will show the broadcasting networks round about you and their channels including your own including the BTWIFI signals
Message 7 of 15
thanks for that "imjolly" i'll try that tomorrow if I get chance, and assuming I have a connection to download, lol.
Message 8 of 15
file is small so as long as a connection even your 'low' 7mb will be fine
Message 9 of 15
I downloaded inssider 2.1 imjolly, some interesting data, what can i do with it?
Had to use WIFI though as my internet is inusable today so am using WIFI from elsewhere.
Message 10 of 15
inssider will show you the wifi networks round about you and the channels on which they are broadcasting and the strength you are reciving their signal.  you want to try to make sure you are on an empty channel and your signal is the strongest you are receiving.  that will mean making changes to the router if necessary
